E6750 Maximale Temperatur?
RaZeR
kann mir jemand sagen die heiß der Intel E6750 maximal werden sollte? Im dauerbetrieb!?
Danke
Gut dankeschön =)
Mein ergebins:
Type: Custom... Min: 8 Max: 4096 InPlace: Yes Mem: 8 Time: 15
CPU: 2799MHz FSB: 333MHz [329MHz x 8.5 est.]
17.07.2007 01:12
Launching 2 threads...
Using CPU #0
Beginning a continuous self-test to check your computer.
Press Stop to end this test.
Test 1, 4000 Lucas-Lehmer iterations of M19922945 using 1024K FFT length.
Test 2, 4000 Lucas-Lehmer iterations of M19922943 using 1024K FFT length.
Test 3, 4000 Lucas-Lehmer iterations of M19374367 using 1024K FFT length.
Self-test 1024K passed!
Test 1, 800000 Lucas-Lehmer iterations of M172031 using 8K FFT length.
Test 2, 800000 Lucas-Lehmer iterations of M163839 using 8K FFT length.
Test 3, 800000 Lucas-Lehmer iterations of M159745 using 8K FFT length.
Test 4, 800000 Lucas-Lehmer iterations of M157695 using 8K FFT length.
Test 5, 800000 Lucas-Lehmer iterations of M155649 using 8K FFT length.
Test 6, 800000 Lucas-Lehmer iterations of M153599 using 8K FFT length.
Test 7, 800000 Lucas-Lehmer iterations of M147455 using 8K FFT length.
Test 8, 800000 Lucas-Lehmer iterations of M143361 using 8K FFT length.
Test 9, 800000 Lucas-Lehmer iterations of M141311 using 8K FFT length.
Self-test 8K passed!
Test 1, 560000 Lucas-Lehmer iterations of M212991 using 10K FFT length.
Test 2, 560000 Lucas-Lehmer iterations of M210415 using 10K FFT length.
Test 3, 560000 Lucas-Lehmer iterations of M208897 using 10K FFT length.
Test 4, 560000 Lucas-Lehmer iterations of M204799 using 10K FFT length.
Test 5, 560000 Lucas-Lehmer iterations of M200705 using 10K FFT length.
Test 6, 560000 Lucas-Lehmer iterations of M196607 using 10K FFT length.
Test 7, 560000 Lucas-Lehmer iterations of M194561 using 10K FFT length.
Test 8, 560000 Lucas-Lehmer iterations of M188415 using 10K FFT length.
Test 9, 560000 Lucas-Lehmer iterations of M186369 using 10K FFT length.
Test 10, 560000 Lucas-Lehmer iterations of M184319 using 10K FFT length.
Self-test 10K passed!
Test 1, 4500 Lucas-Lehmer iterations of M17432577 using 896K FFT length.
Test 2, 4500 Lucas-Lehmer iterations of M17432575 using 896K FFT length.
Test 3, 4500 Lucas-Lehmer iterations of M17115073 using 896K FFT length.
Test 4, 4500 Lucas-Lehmer iterations of M16815071 using 896K FFT length.
Test 5, 4500 Lucas-Lehmer iterations of M16515073 using 896K FFT length.
Self-test 896K passed!
Test 1, 5300 Lucas-Lehmer iterations of M14942209 using 768K FFT length.
Test 2, 5300 Lucas-Lehmer iterations of M14942207 using 768K FFT length.
Torture Test ran 1 hours, 15 minutes 34 seconds - 0 errors, 0 warnings.
Execution halted.
Using CPU #1
Test 11, 800000 Lucas-Lehmer iterations of M172031 using 10K FFT length.
Test 3, 5300 Lucas-Lehmer iterations of M14155777 using 768K FFT length.
Torture Test ran 1 hours, 15 minutes 33 seconds - 0 errors, 0 warnings.
Execution halted.
Ist da alles richtig????
sry is klar aber wollt nochmal auf sicher gehen 😛
Komm jetz aber nicht mehr weiter da mein pc nicht mehr bootet sobald ich den fsb über 353 stelle :-( Ich weiß das man jetz den vcore erhöhen muss jedoch find ich den nicht :-(
LoL,^^... ich hätt mich vorm kauf echt ma genauer erkundigen müssen.. na was solls noch muss ich ja auch eig nicht übertakten! Ach wiso gibt vista auf meinen prozzi die note 5,2?? Der müsste doch 2 odaso haben^^
Kann schon sein, dass der Leistungsindex manchmal nicht sooo fürchterlich genau ist.
Trotzdem: Die gelieferten Werte machen schon Sinn, wenn man bedenkt, dass höhere Zahlenwerte die bessere Bewertung darstellen.
Und Prozzessor-Note 5.2 ist gar nicht mal so schlecht. 😉 (Weil es eh' nicht viel höher geht!)
Huch? ich dacht 1 ist das beste und 6 das schlechteste? (wie in da schul😀)
Mein freund hat die HIS 1950pro 512mb und hat eine bewertung von 2!
Wiso den das schonwieder? die is doch supper und meine on board hat auch zwei!
Na klar ist die 1950 Pro ne gute Karte.
Dass die um Einiges besser als irgendeine Onboardgrafik ist, steht hier ja auch nicht zur Debatte.
Jedwede Grafiklösung, die nicht DX10-fähig ist, bekommt schon mal allerhöchstens two Points.
Hallo zusammen,
habe auch mal eine Frage zu den Temps beim E6750. Es werden folgende Werte angezeigt:​
(Raumtemp bei etwa 24°C, CPU nicht übertaktet, Gehäuse mit 2x 12cm Lüfter bei 6V, Mainboard von ASRock ConRoe 1333-D667, CPU-Kühler k.a. steht was von GlacialTech drauf - sieht billig aus)​
Bei SpeedFan V4.32
Idle
CPU 30
Core1 16
Core2 16​
Bei SpeedFan V4.32
Last (CPU Burn-in)
CPU 37
Core1 29
Core2 30​
Bei Core Temp V0.95.v
Idle
CPU --
Core1 31
Core2 31​
Last (CPU Burn-in)
CPU --
Core1 44
Core2 45​
Die Speedfan werte sind nix. Aber die von Core Temp kommen mir auch zu niedrig vor!?
Die Differenz stimm ja aber ist das die richtige Temp?​
Danke für die schnelle Antwort,​
mich wundert nur das die CPU Temp so niedrig ist ohne ordentlichen Kühler. Die Anzeige im BIOS zeigt 30 oder 35°C.
Wenn die Temperatur einigermaßen richtig angezeigt wird kann ich ja den Lüfter, momentan bei etwas über 3000 rpm, etwas drosseln.​
