CPU-Z version 1.42
Processors Map
Number of processors 1
Number of threads 2
Processor 0
-- Core 0
-- Thread 0
-- Core 1
-- Thread 0
Processors Information
Processor 1 (ID = 0)
Number of cores 2
Number of threads 2 (max 2)
Name AMD Athlon 64 X2 6400+
Codename Windsor
Specification AMD Athlon(tm) 64 X2 Dual Core Processor 6400+
Package Socket AM2 (940)
CPUID F.3.3
Extended CPUID F.43
Brand ID 4
Core Stepping JH-F3
Technology 90 nm
Core Speed 3214.8 MHz (16.0 x 200.9 MHz)
HT Link speed 1004.6 MHz
Stock frequency 3200 MHz
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64
L1 Data cache 2 x 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache 2 x 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 2 x 1024 KBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
max FID 16.0x
max VID 1.450 V
Features XD, VT
K8 Thermal sensor yes
K8 Revision ID 5.3
Attached device PCI device at bus 0, device 24, function 0
Attached device PCI device at bus 0, device 24, function 1
Attached device PCI device at bus 0, device 24, function 2
Attached device PCI device at bus 0, device 24, function 3
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 02002008h
Max CPUID level 00000001h
Max CPUID ext. level 80000018h
Function eax ebx ecx edx
0x00000000 0x00000001 0x68747541 0x444D4163 0x69746E65
0x00000001 0x00040F33 0x00020800 0x00002001 0x178BFBFF
0x80000000 0x80000018 0x68747541 0x444D4163 0x69746E65
0x80000001 0x00040F33 0x000009A7 0x0000001F 0xEBD3FBFF
0x80000002 0x20444D41 0x6C687441 0x74286E6F 0x3620296D
0x80000003 0x32582034 0x61754420 0x6F43206C 0x50206572
0x80000004 0x65636F72 0x726F7373 0x30343620 0x00002B30
0x80000005 0xFF08FF08 0xFF20FF20 0x40020140 0x40020140
0x80000006 0x00000000 0x42004200 0x04008140 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x0000003F
0x80000008 0x00003028 0x00000000 0x00000001 0x00000000
0x80000009 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000A 0x00000001 0x00000040 0x00000000 0x00000000
0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000
0x80000010 0x00000000 0x00000000 0x00000000 0x00000000
0x80000011 0x00000000 0x00000000 0x00000000 0x00000000
0x80000012 0x00000000 0x00000000 0x00000000 0x00000000
0x80000013 0x00000000 0x00000000 0x00000000 0x00000000
0x80000014 0x00000000 0x00000000 0x00000000 0x00000000
0x80000015 0x00000000 0x00000000 0x00000000 0x00000000
0x80000016 0x00000000 0x00000000 0x00000000 0x00000000
0x80000017 0x00000000 0x00000000 0x00000000 0x00000000
0x80000018 0x00000000 0x00000000 0x00000000 0x00000000
Cache descriptor Level 1 I 64 KB 1 threads
Cache descriptor Level 1 D 64 KB 1 threads
Cache descriptor Level 2 U 1 MB 1 threads
MSR 0x0000001B edx = 0x00000000 eax = 0xFEE00900
MSR 0xC001001E edx = 0x00000000 eax = 0x00000053
MSR 0xC0010015 edx = 0x00000000 eax = 0x02000040
MSR 0xC0010042 edx = 0x31041206 eax = 0x04180218
MSR 0xC0010041 edx = 0x00000001 eax = 0x00000618
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 1, Thread ID 0
Type 02002008h
0x00000001 0x00040F33 0x01020800 0x00002001 0x178BFBFF
MSR 0x0000001B edx = 0x00000000 eax = 0xFEE00800
Chipset
Northbridge ATI RD790 rev. 00
Southbridge ATI SB600 rev. 00
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR2
Memory Size 4096 MBytes
Channels Single
Memory Frequency 401.9 MHz (CPU/8)
CAS# 5.0
RAS# to CAS# 5
RAS# Precharge 5
Cycle Time (tRAS) 18
Bank Cycle Time (tRC) 22
Command Rate 2T
Memory SPD
DIMM #1
General
Memory type DDR2
Module format Regular UDIMM
Manufacturer (ID) Kingmax Semiconductor (7F7F7F2500000000)
Size 2048 MBytes
Max bandwidth PC2-6400 (400 MHz)
Part number KLDE88F-B8KB5
Attributes
Number of banks 2
Data width 64 bits
Correction None
Nominal Voltage 1.80 Volts
EPP no
XMP no
Timings table
Frequency (MHz) 200 266 400
CAS# 3.0 4.0 5.0
RAS# to CAS# delay 3 4 5
RAS# Precharge 3 4 5
TRAS 9 12 18
TRC 12 16 23
DIMM #2
General
Memory type DDR2
Size 2048 MBytes
Attributes
Number of banks 2
Data width 64 bits
Correction None
EPP no
XMP no
Timings table
CAS# 3.0 4.0 5.0
TRAS 9 12 18
TRC 12 16 23
Dump Module #1
0 1 2 3 4 5 6 7 8 9 A B C D E F
00 80 08 08 0E 0A 61 40 00 05 25 40 00 82 08 00 00
10 0C 08 38 01 02 00 03 3D 50 50 60 32 1E 32 2D 01
20 17 25 05 12 3C 1E 1E 00 00 39 7F 80 14 1E 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 C3
40 7F 7F 7F 25 00 00 00 00 41 4B 4C 44 45 38 38 46
50 2D 42 38 4B 42 35 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
90 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Dump Module #2
Monitoring
Mainboard Model GA-MA790FX-DS5 (0x37A - 0x9977C610)
LPCIO
Vendor ITE
Model IT8718
Vendor ID 0x90
Chip ID 0x8718
Revision ID 0x4
Config Mode I/O address 0x2E
Dump config mode register space, LDN = 0x4
00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 87 18 04 10 1A 00 23 00 40 80 00 00 1D 00 00 00
30 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 02 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 02 00 00 04 04 00 00 00 00 00 00 00 00 00 00
Hardware monitor
ITE IT87 hardware monitor
Voltage sensor 0 1.42 Volts [0x59] (CPU VCORE)
Voltage sensor 1 1.89 Volts [0x76] (VIN1)
Voltage sensor 2 3.36 Volts [0xD2] (+3.3V)
Voltage sensor 3 5.16 Volts [0xC0] (+5V)
Voltage sensor 4 12.48 Volts [0xC3] (+12V)
Voltage sensor 5 -12.99 Volts [0xCB] (-12V)
Voltage sensor 8 3.06 Volts [0xBF] (VBAT)
Temperature sensor 0 33°C (91°F) [0x21] (TMPIN0)
Temperature sensor 1 25°C (76°F) [0x19] (TMPIN1)
Temperature sensor 2 80°C (175°F) [0x50] (TMPIN2)
Fan sensor 0 1184 RPM [0x23A] (FANIN0)
Fan sensor 2 1570 RPM [0x1AE] (FANIN2)
Dump hardware monitor
LPC Register space, base address = 0x0228
00 11 10 C0 00 FF FF 00 37 FF 87 54 09 27 39 FF AD
10 FF FF FF 73 D7 81 80 7F 02 FF 01 FF FF FF FF FF
20 59 75 D3 C1 C4 CB FF 00 BF 21 19 50 80 BF 38 38
30 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00
40 7F 7F 7F 7F 7F 7F 5F 74 2D 40 90 22 FF FF FF FF
50 FF 2A 7F 7F 7F 50 04 04 90 04 33 12 60 00 00 00
60 00 14 41 27 90 03 FF FF 00 14 41 23 90 03 FF FF
70 00 14 41 20 90 03 FF FF FF FF FF FF FF FF FF FF
80 00 00 FF FF 00 00 FF FF 00 00 00 00 00 00 02 00
90 FF 00 00 00 FF 00 00 00 FF FF FF FF FF FF FF FF
A0 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF
Hardware monitor
AMD Athlon 64 X2 6400+ hardware monitor
Temperature sensor 0 24°C (75°F) [0x49] (core #0)
Temperature sensor 1 24°C (75°F) [0x49] (core #1)
PCI Device List
Host Bridge
bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x5956
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x20
Header 0x00
PCI header
Address 3 (memory) 0xE0000000
Subvendor ID 0x1002
Subsystem ID 0x5956
Int. Line 0x00
Int. Pin 0x00
Capabilities
HyperTransport Capability
Offset C4h
Revision 3.00
Interface type Slave/Primary
Link 0 width (in/out) 16 bits/16 bits
Link 0 frequency 1000MHz
Link 1 width (in/out) 8 bits/8 bits
Link 1 frequency 200MHz
Offset 40h
Interface type Retry Mode
Offset 54h
Interface type Clumping
Offset 9Ch
Interface type Gen3
Dump
00 02 10 56 59 06 00 30 22 00 00 00 06 00 20 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 04 00 00 E0
20 00 00 00 00 00 00 00 00 00 00 00 00 02 10 56 59
30 00 00 00 00 C4 00 00 00 00 00 00 00 00 00 00 00
40 08 54 00 C0 C0 00 00 00 00 00 00 00 42 20 05 00
50 02 10 56 59 08 9C 00 90 08 10 00 00 00 00 40 64
60 7D 00 00 00 01 00 00 00 00 02 20 00 60 50 00 78
70 00 00 00 00 00 00 00 00 82 32 0F 00 00 00 00 00
80 00 00 00 00 10 00 00 03 20 01 30 00 31 20 00 00
90 00 00 00 D0 7D 00 00 00 00 00 00 00 08 00 3C D0
A0 7A 00 00 00 00 00 00 05 00 00 00 00 71 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 80 08 40 80 01 20 00 11 11 D0 00 00 00
D0 60 06 F5 7F 02 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 05 00 FF FF FF FF 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 80 80 00 00 00 00 00 00 00 00 00
PCI to PCI Bridge
bus 0 (0x00), device 2 (0x02), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x5978
Revision ID 0x00
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x01
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0xFF
Int. Pin 0x00
Capabilities
Power Management Capability
Offset 50h
Version 1.2
PCI Express Capability
Offset 58h
Device type Root Port of PCI-E Root Complex
Port 0
Version 2.0
Physical slot Integrated device
Link width 16x (max 16x)
Message Signalled Interrupts Capability
Offset A0h
Subsystem Vendor Capability
Offset B0h
Subsystem ID 0x5956
Sub. Vendor ID 0x1002
Offset B8h
Interface type MSI Mapping
Extended capabilities
Vendor Specific
Offset 100h
Vendor ID 1
Size 16
Virtual Channel
Offset 110h
Dump
00 02 10 78 59 07 00 10 00 00 00 04 06 01 00 01 00
10 00 00 00 00 00 00 00 00 00 01 01 00 D1 D1 00 20
20 90 FD 90 FD 01 D0 F1 DF 00 00 00 00 00 00 00 00
30 00 00 00 00 50 00 00 00 00 00 00 00 FF 00 08 00
50 01 58 03 C8 00 00 00 00 10 A0 42 00 20 80 00 00
60 10 08 00 00 02 0D 10 00 40 00 02 31 80 3A 14 00
70 00 00 40 01 00 00 01 00 00 00 00 00 1F 00 00 00
80 00 00 00 00 00 00 00 00 42 00 01 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 05 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 0D B8 00 00 02 10 56 59 08 00 03 A8 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 50 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
100 0B 00 01 11 01 00 01 01 00 00 00 00 00 00 00 00
110 02 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00
120 01 00 00 00 FF 00 00 80 00 00 00 00 01 00 00 00
130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PCI to PCI Bridge
bus 0 (0x00), device 7 (0x07), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x597D
Revision ID 0x00
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x01
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x02
Int. Line 0xFF
Int. Pin 0x00
Capabilities
Offset 50h
Version 1.2
Offset 58h
Port 3
Version 2.0
Link width 1x (max 1x)
Offset A0h
Offset B0h
Subsystem ID 0x5956
Offset B8h
Vendor Specific
Offset 100h
Vendor ID 1
Size 16
Virtual Channel
Offset 110h
Dump
00 02 10 7D 59 07 00 10 00 00 00 04 06 01 00 01 00
10 00 00 00 00 00 00 00 00 00 02 02 00 C1 C1 00 00
20 F0 FD F0 FD E1 FD E1 FD 00 00 00 00 00 00 00 00
30 00 00 00 00 50 00 00 00 00 00 00 00 FF 00 04 00
60 10 08 00 00 12 0C 10 03 40 00 11 30 80 0C 3C 00
80 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00
E0 50 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00
PCI to PCI Bridge
bus 0 (0x00), device 9 (0x09), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x597E
Revision ID 0x00
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x01
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x03
Int. Line 0xFF
Int. Pin 0x00
Capabilities
Offset 50h
Version 1.2
Offset 58h
Port 4
Version 2.0
Offset A0h
Offset B0h
Subsystem ID 0x5956
Offset B8h
Vendor Specific
Offset 100h
Vendor ID 1
Size 16
Virtual Channel
Offset 110h
Dump
00 02 10 7E 59 07 00 10 00 00 00 04 06 01 00 01 00
10 00 00 00 00 00 00 00 00 00 03 03 00 B1 B1 00 00
20 D0 FD D0 FD C1 FD C1 FD 00 00 00 00 00 00 00 00
60 10 08 00 00 12 0C 10 04 40 00 11 30 80 0C 4C 00
PCI to PCI Bridge
bus 0 (0x00), device 10 (0x0A), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x597F
Revision ID 0x00
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x01
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x04
Int. Line 0xFF
Int. Pin 0x00
Capabilities
Offset 50h
Version 1.2
Offset 58h
Port 5
Version 2.0
Offset A0h
Offset B0h
Subsystem ID 0x5956
Offset B8h
Vendor Specific
Offset 100h
Vendor ID 1
Size 16
Virtual Channel
Offset 110h
Dump
00 02 10 7F 59 07 00 10 00 00 00 04 06 01 00 01 00
10 00 00 00 00 00 00 00 00 00 04 04 00 E1 E1 00 00
20 B0 FD B0 FD A1 FD A1 FD 00 00 00 00 00 00 00 00
60 10 08 00 00 12 0C 10 05 40 00 11 30 80 0C 54 00
IDE Controller
bus 0 (0x00), device 18 (0x12), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x4380
Revision ID 0x00
PI 0x8F
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x20
Header 0x00
PCI header
Address 0 (port) 0x0000FF00
Address 1 (port) 0x0000FE00
Address 2 (port) 0x0000FD00
Address 3 (port) 0x0000FC00
Address 4 (port) 0x0000FB00
Address 5 (memory) 0xFE02F000
Subvendor ID 0x1458
Subsystem ID 0xB002
Int. Line 0x16
Int. Pin 0x01
Capabilities
Offset 60h
Version 1.1
Dump
00 02 10 80 43 07 00 30 02 00 8F 01 01 00 20 00 00
10 01 FF 00 00 01 FE 00 00 01 FD 00 00 01 FC 00 00
20 01 FB 00 00 00 F0 02 FE 00 00 00 00 58 14 02 B0
30 00 00 00 00 60 00 00 00 00 00 00 00 16 01 00 00
40 10 00 80 02 01 00 10 00 01 00 00 00 00 00 00 00
50 05 00 84 00 00 00 00 00 00 00 00 00 00 00 00 00
60 01 00 22 00 00 00 00 00 00 00 00 00 00 00 00 00
70 12 00 10 00 0F 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 06 00 00 2C D6 00 B4 00 D6 00 B4 00
90 D6 00 B4 00 D6 00 B4 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 B8 00 00 00 00 00 00 00 B8 00 00
B0 00 00 00 00 00 B8 00 00 00 00 00 00 00 B8 00 00
C0 00 20 00 00 80 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
USB Controller (OHCI)
bus 0 (0x00), device 19 (0x13), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x4387
Revision ID 0x00
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x01
Latency 0x20
Header 0x80
PCI header
Address 0 (memory) 0xFE02E000
Subvendor ID 0x1458
Subsystem ID 0x5004
Int. Line 0x10
Int. Pin 0x01
Dump
00 02 10 87 43 07 00 A0 02 00 10 03 0C 01 20 80 00
10 00 E0 02 FE 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 58 14 04 50
30 00 00 00 00 00 00 00 00 00 00 00 00 10 01 00 00
40 80 1F 00 00 0A 84 B7 18 07 35 00 00 00 00 00 00
50 00 9C 00 00 00 00 00 00 FF FF FF FF FF 00 00 00
70 00 00 00 00 FF 00 00 80 00 00 00 00 00 00 00 00
80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
bus 0 (0x00), device 19 (0x13), function 1 (0x01)
Common header
Vendor ID 0x1002
Model ID 0x4388
Revision ID 0x00
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x01
Latency 0x20
Header 0x00
PCI header
Address 0 (memory) 0xFE02D000
Subvendor ID 0x1458
Subsystem ID 0x5004
Int. Line 0x11
Int. Pin 0x02
Dump
00 02 10 88 43 07 00 A0 02 00 10 03 0C 01 20 00 00
10 00 D0 02 FE 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 11 02 00 00
bus 0 (0x00), device 19 (0x13), function 2 (0x02)
Common header
Vendor ID 0x1002
Model ID 0x4389
Revision ID 0x00
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x01
Latency 0x20
Header 0x00
PCI header
Address 0 (memory) 0xFE02C000
Subvendor ID 0x1458
Subsystem ID 0x5004
Int. Line 0x12
Int. Pin 0x03
Dump
00 02 10 89 43 07 00 A0 02 00 10 03 0C 01 20 00 00
10 00 C0 02 FE 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 12 03 00 00
bus 0 (0x00), device 19 (0x13), function 3 (0x03)
Common header
Vendor ID 0x1002
Model ID 0x438A
Revision ID 0x00
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x01
Latency 0x20
Header 0x00
PCI header
Address 0 (memory) 0xFE02B000
Subvendor ID 0x1458
Subsystem ID 0x5004
Int. Line 0x11
Int. Pin 0x02
Dump
00 02 10 8A 43 07 00 A0 02 00 10 03 0C 01 20 00 00
10 00 B0 02 FE 00 00 00 00 00 00 00 00 00 00 00 00
bus 0 (0x00), device 19 (0x13), function 4 (0x04)
Common header
Vendor ID 0x1002
Model ID 0x438B
Revision ID 0x00
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x01
Latency 0x20
Header 0x00
PCI header
Address 0 (memory) 0xFE02A000
Subvendor ID 0x1458
Subsystem ID 0x5004
Int. Line 0x12
Int. Pin 0x03
Dump
00 02 10 8B 43 07 00 A0 02 00 10 03 0C 01 20 00 00
10 00 A0 02 FE 00 00 00 00 00 00 00 00 00 00 00 00
USB 2.0 Controller (EHCI)
bus 0 (0x00), device 19 (0x13), function 5 (0x05)
Common header
Vendor ID 0x1002
Model ID 0x4386
Revision ID 0x00
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x01
Latency 0x20
Header 0x00
PCI header
Address 0 (memory) 0xFE029000
Subvendor ID 0x1458
Subsystem ID 0x5004
Int. Line 0x13
Int. Pin 0x04
Capabilities
Offset C0h
Version 1.1
Debug Port Capability
Offset E4h
Dump
00 02 10 86 43 07 00 B0 02 00 20 03 0C 01 20 00 00
10 00 90 02 FE 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 C0 00 00 00 00 00 00 00 13 04 00 00
50 40 00 0E 00 00 00 00 00 00 00 00 00 00 00 00 00
60 20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 01 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00
C0 01 E4 02 7E 00 00 40 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 0A 00 E0 20 00 00 00 00 00 00 00 00
SMBus Controller
bus 0 (0x00), device 20 (0x14), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x4385
Revision ID 0x14
PI 0x00
SubClass 0x05
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (port) 0x00000B00
Subvendor ID 0x1458
Subsystem ID 0x4385
Int. Line 0x00
Int. Pin 0x00
Capabilities
Offset B0h
Dump
00 02 10 85 43 03 04 30 02 14 00 05 0C 00 00 80 00
10 01 0B 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 58 14 85 43
30 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00
40 D4 39 00 05 00 00 00 00 0F FF 00 00 00 00 00 00
50 F0 01 F0 0E F0 0F F0 0F 11 0B F0 0F 00 00 00 00
60 01 00 24 00 BF FD 9E 83 3F 90 00 00 20 00 00 00
70 00 01 00 00 08 00 C0 FE FF 6E 00 00 00 00 F0 0F
80 E1 0B F0 0F 00 00 00 00 00 00 00 00 8C 00 00 80
90 01 0B 00 00 BA DE FF 00 00 00 00 00 00 00 00 00
A0 00 00 FF FF FF FF E1 19 00 FF 14 06 16 7B 20 18
B0 08 00 02 A8 00 00 00 00 00 00 00 00 F0 0F 08 1A
C0 FF FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 D8 0C 00 00 00 00 44 00 00 00 00 00 AA 00 10 01
IDE Controller
bus 0 (0x00), device 20 (0x14), function 1 (0x01)
Common header
Vendor ID 0x1002
Model ID 0x438C
Revision ID 0x00
PI 0x8A
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x20
Header 0x00
PCI header
Address 4 (port) 0x0000F900
Subvendor ID 0x1458
Subsystem ID 0x5002
Int. Line 0xFF
Int. Pin 0x01
Dump
00 02 10 8C 43 05 00 20 02 00 8A 01 01 00 20 00 00
10 01 00 00 00 01 00 00 00 01 00 00 00 01 00 00 00
20 01 F9 00 00 00 00 00 00 00 00 00 00 58 14 02 50
30 00 00 00 00 00 00 00 00 00 00 00 00 FF 01 00 00
40 99 20 00 00 FF FF 00 00 00 00 04 00 00 00 00 00
50 00 00 00 00 01 00 02 00 00 00 00 00 00 00 00 00
60 00 00 40 00 10 2C 01 07 01 00 00 00 FF FF 0F 00
70 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Multimedia device
bus 0 (0x00), device 20 (0x14), function 2 (0x02)
Common header
Vendor ID 0x1002
Model ID 0x4383
Revision ID 0x00
PI 0x00
SubClass 0x03
BaseClass 0x04
Cache Line 0x01
Latency 0x20
Header 0x00
PCI header
Address 0 (memory) 0xFE024000
Subvendor ID 0x1458
Subsystem ID 0xA022
Int. Line 0x10
Int. Pin 0x01
Capabilities
Offset 50h
Version 1.1
Dump
00 02 10 83 43 06 00 10 04 00 00 03 04 01 20 00 00
10 04 40 02 FE 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 58 14 22 A0
30 00 00 00 00 50 00 00 00 00 00 00 00 10 01 00 00
40 00 00 00 00 01 00 00 00 00 00 00 00 01 00 00 00
50 01 00 42 C8 00 00 00 00 00 00 00 00 00 00 00 00
60 05 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00
PCI to ISA Bridge
bus 0 (0x00), device 20 (0x14), function 3 (0x03)
Common header
Vendor ID 0x1002
Model ID 0x438D
Revision ID 0x00
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1458
Subsystem ID 0x5001
Int. Line 0x00
Int. Pin 0x00
Dump
00 02 10 8D 43 0F 00 20 02 00 00 01 06 00 00 80 00
20 00 00 00 00 00 00 00 00 00 00 00 00 58 14 01 50
40 04 00 00 00 FF FF C3 FF 3F FF 42 00 00 00 00 00
60 00 00 00 00 00 0A 00 00 0E 00 0F 00 B8 FF FF FF
70 67 45 23 01 00 00 00 00 01 00 00 00 05 00 00 00
80 08 00 03 A8 00 00 00 00 00 00 00 00 00 00 00 00
B0 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PCI to PCI Bridge
bus 0 (0x00), device 20 (0x14), function 4 (0x04)
Common header
Vendor ID 0x1002
Model ID 0x4384
Revision ID 0x00
PI 0x01
SubClass 0x04
BaseClass 0x06
Cache Line 0x00
Latency 0x40
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x05
Int. Line 0x00
Int. Pin 0x00
Dump
00 02 10 84 43 27 00 A0 02 00 01 04 06 00 40 81 00
10 00 00 00 00 00 00 00 00 00 05 05 40 F0 00 80 22
20 F0 FF 00 00 F0 FF 00 00 00 00 00 00 00 00 00 00
40 26 00 0C FF 00 00 00 00 0C 01 3F D1 00 00 00 00
50 01 00 00 00 08 00 03 A8 00 00 00 00 85 00 FF FF
60 CA 0E 17 00 BA 18 10 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 01 00 02 06
E0 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00
Host Bridge
bus 0 (0x00), device 24 (0x18), function 0 (0x00)
Common header
Vendor ID 0x1022
Model ID 0x1100
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
Capabilities
Offset 80h
Revision 1.02
Interface type Host/Secondary
Device number 0
Dump
00 22 10 00 11 00 00 10 00 00 00 00 06 00 00 80 00
20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00
40 01 01 01 00 01 01 01 00 01 01 01 00 01 01 01 00
50 01 01 01 00 01 01 01 00 01 01 01 00 01 01 01 00
60 00 00 01 00 E4 00 00 00 20 C8 2E 0F 0C 00 00 00
80 08 00 01 21 20 00 11 11 22 06 75 80 02 00 00 00
90 78 01 70 01 00 00 05 00 07 00 00 00 00 00 00 00
Host Bridge
bus 0 (0x00), device 24 (0x18), function 1 (0x01)
Common header
Vendor ID 0x1022
Model ID 0x1101
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
Dump
00 22 10 01 11 00 00 00 00 00 00 00 06 00 00 80 00
40 03 00 00 00 00 00 2F 01 00 00 00 00 01 00 00 00
50 00 00 00 00 02 00 00 00 00 00 00 00 03 00 00 00
60 00 00 00 00 04 00 00 00 00 00 00 00 05 00 00 00
70 00 00 00 00 06 00 00 00 00 00 00 00 07 00 00 00
80 03 0A 00 00 00 0B 00 00 00 00 00 00 00 00 00 00
90 03 00 D0 00 00 02 FE 00 00 00 00 00 00 00 00 00
B0 03 00 E0 00 80 FF EF 00 00 00 00 00 00 00 00 00
C0 13 A0 00 00 00 F0 00 00 00 00 00 00 00 00 00 00
E0 03 00 00 05 34 03 3D EE 14 03 EF FE 74 00 7F FF
F0 01 30 00 D0 00 00 00 00 00 00 00 00 00 00 00 00
Host Bridge
bus 0 (0x00), device 24 (0x18), function 2 (0x02)
Common header
Vendor ID 0x1022
Model ID 0x1102
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
Dump
00 22 10 02 11 00 00 00 00 00 00 00 06 00 00 80 00
50 01 00 00 00 01 01 00 00 01 02 00 00 01 03 00 00
60 00 00 00 00 00 00 00 00 E0 3C F8 00 E0 3C F8 00
70 00 00 00 00 00 00 00 00 46 00 00 00 00 00 00 00
80 00 55 00 00 00 00 00 00 24 F2 1B FF 20 12 02 48
90 30 00 01 00 6B 00 50 77 10 00 00 80 00 00 00 00
A0 FB 02 00 0C 00 00 00 00 00 00 00 00 00 00 00 00
B0 C6 E2 34 CE A5 00 00 00 21 28 9B 20 15 F0 8F D1
D0 13 FF C7 E1 56 DC F7 0F 5D 66 13 74 1A 3A 21 E7
E0 0B EF F3 F1 04 CD 93 25 0E A7 29 1D 4B 1D 38 A7
Host Bridge
bus 0 (0x00), device 24 (0x18), function 3 (0x03)
Common header
Vendor ID 0x1022
Model ID 0x1103
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
Capabilities
Secure Device Capability
Offset F0h
Dump
00 22 10 03 11 00 00 10 00 00 00 00 06 00 00 80 00
30 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00
40 FF 3B 04 00 40 00 10 0A 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 78 F0 7D
60 77 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 11 01 02 51 11 80 00 50 00 2A 00 08 2A 23 00 00
80 00 00 07 23 13 21 13 21 00 00 00 00 00 00 00 00
90 00 00 00 00 1F 70 00 00 F0 0A F1 DB 00 00 00 00
D0 00 00 00 00 01 A7 0D 00 00 00 40 00 25 00 00 00
E0 00 00 00 00 24 16 4A 00 19 17 00 00 00 00 00 00
F0 0F 00 10 00 00 00 00 00 00 00 00 00 33 0F 04 00
VGA Controller
bus 1 (0x01), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x9501
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x01
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xD0000000
Address 2 (memory) 0xFD9E0000
Address 4 (port) 0x0000DE00
Subvendor ID 0x1002
Subsystem ID 0x2542
Int. Line 0x12
Int. Pin 0x01
Capabilities
Offset 50h
Version 1.2
Offset 58h
Device type Legacy PCI-E Endpoint Device
Port 0
Version 2.0
Offset A0h
Vendor Specific
Offset 100h
Vendor ID 1
Size 16
Dump
00 02 10 01 95 07 00 10 00 00 00 00 03 01 00 80 00
10 0C 00 00 D0 00 00 00 00 04 00 9E FD 00 00 00 00
20 01 DE 00 00 00 00 00 00 00 00 00 00 02 10 42 25
30 00 00 00 00 50 00 00 00 00 00 00 00 12 01 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 02 10 42 25
50 01 58 03 06 00 00 00 00 10 A0 12 00 A0 8F 00 00
60 10 08 00 00 02 0D 00 00 40 00 02 11 00 00 00 00
80 00 00 00 00 00 00 00 00 02 00 00 00 00 00 00 00
A0 05 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00
100 0B 00 01 00 01 00 01 01 00 00 00 00 00 00 00 00
Multimedia device
bus 1 (0x01), device 0 (0x00), function 1 (0x01)
Common header
Vendor ID 0x1002
Model ID 0xAA18
Revision ID 0x00
PI 0x00
SubClass 0x03
BaseClass 0x04
Cache Line 0x01
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xFD9FC000
Subvendor ID 0x1002
Subsystem ID 0xAA18
Int. Line 0x13
Int. Pin 0x02
Capabilities
Offset 50h
Version 1.2
Offset 58h
Port 0
Version 2.0
Offset A0h
Vendor Specific
Offset 100h
Vendor ID 1
Size 16
Dump
00 02 10 18 AA 07 00 10 00 00 00 03 04 01 00 80 00
10 04 C0 9F FD 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 02 10 18 AA
30 00 00 00 00 50 00 00 00 00 00 00 00 13 02 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 02 10 18 AA
Ethernet Controller
bus 2 (0x02), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x10EC
Model ID 0x8168
Revision ID 0x01
PI 0x00
SubClass 0x00
BaseClass 0x02
Cache Line 0x01
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x0000CC00
Address 2 (memory) 0xFDFFF000
Subvendor ID 0x1458
Subsystem ID 0xE000
Int. Line 0x13
Int. Pin 0x01
Capabilities
Offset 40h
Version 1.1
Virtual Product Data Capability
Offset 48h
Offset 50h
Offset 60h
Device type PCI-E Endpoint Device
Port 0
Version 1.0
Vendor Dependant Capability
Offset 84h
Advanced Error Reporting Capability
Offset 100h
Virtual Channel
Offset 12Ch
Device Serial Number
Offset 148h
Power Budgeting Capability
Offset 154h
Dump
00 EC 10 68 81 07 00 10 00 01 00 00 02 01 00 00 00
10 01 CC 00 00 00 00 00 00 04 F0 FF FD 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 58 14 00 E0
30 00 00 00 00 40 00 00 00 00 00 00 00 13 01 00 00
40 01 48 C2 F7 00 00 00 00 03 50 00 00 00 00 00 00
50 05 60 82 00 00 00 00 00 00 00 00 00 00 00 00 00
60 10 84 01 00 63 7E 00 00 10 58 10 00 11 F4 03 00
70 40 00 11 10 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 09 00 4C 01 01 1C 02 00 FB FF FF 11
90 08 30 00 00 FB AA 07 00 59 91 07 00 EA 0A 00 00
A0 02 28 FF 01 00 00 00 00 00 08 00 00 03 00 03 00
B0 00 40 00 00 FF 3F FF 3F FF FF 00 00 00 00 00 00
100 01 00 C1 12 00 00 10 00 00 00 00 00 11 20 06 00
110 00 00 00 00 00 00 00 00 14 00 00 00 01 00 00 04
120 0F 01 00 00 00 00 01 02 2E 8B 87 42 02 00 81 14
Serial ATA Controller
bus 3 (0x03), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x197B
Model ID 0x2363
Revision ID 0x02
PI 0x01
SubClass 0x06
BaseClass 0x01
Cache Line 0x01
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x0000BCE8
Address 1 (port) 0x0000BCDC
Address 2 (port) 0x0000BCE0
Address 3 (port) 0x0000BC00
Address 4 (port) 0x0000BCF0
Address 5 (memory) 0xFDDFE000
Subvendor ID 0x1458
Subsystem ID 0xB000
Int. Line 0x11
Int. Pin 0x01
Capabilities
Offset 68h
Version 1.1
Offset 50h
Port 1
Version 1.0
Dump
00 7B 19 63 23 07 00 10 00 02 01 06 01 01 00 00 00
10 E9 BC 00 00 DD BC 00 00 E1 BC 00 00 01 BC 00 00
20 F1 BC 00 00 00 E0 DF FD 00 00 00 00 58 14 00 B0
30 00 00 00 00 68 00 00 00 00 00 00 00 11 01 00 00
40 B1 A1 82 00 08 08 FF F0 20 00 00 24 00 00 00 00
50 10 00 11 02 00 00 00 00 00 20 08 00 11 44 02 01
60 40 00 11 10 00 00 00 00 01 50 02 40 00 00 00 00
80 08 08 00 00 A0 01 0A 00 0F AA 0F AA 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80
C0 C3 8B 38 00 03 45 02 00 9C 34 27 C0 49 92 00 00
D0 18 00 80 80 01 00 00 00 03 50 EB 00 00 00 00 02
E0 00 00 00 00 00 00 00 00 9C 34 27 C0 49 92 00 89
100 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
110 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
120 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE Controller
bus 4 (0x04), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x197B
Model ID 0x2363
Revision ID 0x02
PI 0x85
SubClass 0x01
BaseClass 0x01
Cache Line 0x01
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x0000ECE8
Address 1 (port) 0x0000ECDC
Address 2 (port) 0x0000ECE0
Address 3 (port) 0x0000EC00
Address 4 (port) 0x0000ECF0
Address 5 (memory) 0xFDBFE000
Subvendor ID 0x1458
Subsystem ID 0xB000
Int. Line 0x12
Int. Pin 0x01
Capabilities
Offset 68h
Version 1.1
Offset 50h
Port 1
Version 1.0
Dump
00 7B 19 63 23 07 00 10 00 02 85 01 01 01 00 00 00
10 E9 EC 00 00 DD EC 00 00 E1 EC 00 00 01 EC 00 00
20 F1 EC 00 00 00 E0 BF FD 00 00 00 00 58 14 00 B0
30 00 00 00 00 68 00 00 00 00 00 00 00 12 01 00 00
40 B1 A1 C0 00 08 08 FF E0 20 00 00 24 00 00 00 00
80 08 08 A0 00 A0 01 0A 00 0F AA 0F 00 00 00 00 00
D0 18 00 80 80 01 00 00 00 01 90 EB 00 00 00 00 01
OHCI FireWire Controller
bus 5 (0x05), device 14 (0x0E), function 0 (0x00)
Common header
Vendor ID 0x104C
Model ID 0x8024
Revision ID 0x00
PI 0x10
SubClass 0x00
BaseClass 0x0C
Cache Line 0x01
Latency 0x20
Header 0x00
PCI header
Address 0 (memory) 0xFD8FF000
Address 1 (memory) 0xFD8F8000
Subvendor ID 0x1458
Subsystem ID 0x1000
Int. Line 0x16
Int. Pin 0x01
Capabilities
Offset 44h
Version 1.1
Dump
00 4C 10 24 80 06 00 10 02 00 10 00 0C 01 20 00 00
10 00 F0 8F FD 00 80 8F FD 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 58 14 00 10
30 00 00 00 00 44 00 00 00 00 00 00 00 16 01 02 04
40 00 00 00 00 01 00 02 7E 00 80 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 08 00 00 00
F0 10 00 00 00 86 10 00 00 58 14 00 10 00 00 00 00
DMI
DMI BIOS
vendor Award Software International, Inc.
version F2
date 11/23/2007
DMI System Information
manufacturer Gigabyte Technology Co., Ltd.
product GA-MA790FX-DS5
version unknown
serial unknown
UUID 30303141-34443538-45344435-FFFFFFFF
DMI Baseboard
vendor Gigabyte Technology Co., Ltd.
model GA-MA790FX-DS5
revision x.x
serial unknown
DMI System Enclosure
chassis type Desktop
chassis serial unknown
DMI Processor
manufacturer AMD
model AMD Athlon(tm) 64 X2 Dual Core Processor 6400+
clock speed 3200.0MHz
FSB speed 200.0MHz
multiplier 16.0x
DMI Memory Controller
correction 64-bit ECC
Max module size 1024MBytes
DMI Memory Module
designation A0
DMI Memory Module
designation A1
size 2048MBytes (double bank)
DMI Memory Module
designation A2
DMI Memory Module
designation A3
DMI Port Connector
designation PRIMARY IDE (internal)
connector On Board IDE
DMI Port Connector
designation FDD (internal)
port type 8251 FIFO Compatible
connector On Board Floppy
DMI Port Connector
designation COM1 (internal)
port type Serial Port 16450
connector 9 Pin Dual Inline (pin 10 cut)
connector DB-9 male
DMI Port Connector
designation COM2 (internal)
connector DB-9 male
DMI Port Connector
designation LPT1 (internal)
port type Parallel Port ECP/EPP
connector DB-25 female
DMI Port Connector
designation Keyboard (internal)
port type Keyboard Port
connector PS/2
DMI Port Connector
designation PS/2 Mouse (internal)
designation Detected (external)
port type Mouse Port
connector PS/2
connector PS/2
DMI Port Connector
designation USB (internal)
port type USB
connector Access Bus (USB)
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Extension Slot
designation PCI
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI Express
type A5
DMI Extension Slot
type A5
DMI Extension Slot
type A5
DMI Extension Slot
type A5
DMI Extension Slot
type A5
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 2048MBytes
max# of devices 4
DMI Memory Device
designation A0
format DIMM
type unknown
total width 64bits
data width 64bits
DMI Memory Device
designation A1
format DIMM
type unknown
total width 64bits
data width 64bits
size 2048MBytes
DMI Memory Device
designation A2
format DIMM
type unknown
total width 64bits
data width 64bits
DMI Memory Device
designation A3
format DIMM
type unknown
total width 64bits
data width 64bits
size 2048MBytes
Software
Windows Version Microsoft Windows XP Professional Service Pack 2 (Build 2600)
DirectX Version 9.0c
Resources
Memory I/O Space, BA=0x00000000E0000000
Port I/O Space, BA=0xFF00
Port I/O Space, BA=0xFE00
Port I/O Space, BA=0xFD00
Port I/O Space, BA=0xFC00
Port I/O Space, BA=0xFB00
Memory I/O Space, BA=0x00000000FE02F000
Memory I/O Space, BA=0x00000000FE02E000
Memory I/O Space, BA=0x00000000FE02D000
Memory I/O Space, BA=0x00000000FE02C000
Memory I/O Space, BA=0x00000000FE02B000
Memory I/O Space, BA=0x00000000FE02A000
Memory I/O Space, BA=0x00000000FE029000
Port I/O Space, BA=0xB00
Port I/O Space, BA=0xF900
Memory I/O Space, BA=0x00000000FE024000
Memory I/O Space, BA=0x00000000D0000000
Memory I/O Space, BA=0x00000000FD9E0000
Port I/O Space, BA=0xDE00
Memory I/O Space, BA=0x00000000FD9FC000
Port I/O Space, BA=0xCC00
Memory I/O Space, BA=0x00000000FDFFF000
Port I/O Space, BA=0xBCE8
Port I/O Space, BA=0xBCDC
Port I/O Space, BA=0xBCE0
Port I/O Space, BA=0xBC00
Port I/O Space, BA=0xBCF0
Memory I/O Space, BA=0x00000000FDDFE000
Port I/O Space, BA=0xECE8
Port I/O Space, BA=0xECDC
Port I/O Space, BA=0xECE0
Port I/O Space, BA=0xEC00
Port I/O Space, BA=0xECF0
Memory I/O Space, BA=0x00000000FDBFE000
Memory I/O Space, BA=0x00000000FD8FF000
Memory I/O Space, BA=0x00000000FD8F8000
Memory I/O Space, BA=0x00000000E0000000, size=0x1000
Port I/O Space, BA=0x4008, size=0x4
Memory I/O Space, BA=0x00000000FEE00000, size=0x1000
Port I/O Space, BA=0x228
Port I/O Space, BA=0x2E
