MS Visual C++2008 installieren geht nicht
PC_69
Hallo Zusammen
Ich versuche gerade das Steuererklärungsprogramm ELSTER2010 zu installieren.
Hierzu wird auch MS Visual C++2008 Redistributable benötigt.
Das Programm vcredist_x86_2008_sp1 bricht aber immer ab. Process returning code 1601
Wie bekomme ich das Problem in den Griff ?
Hier der Eintrag aus der Logdatei:
[01/30/10,14:59:56] ========== Logging started ==========
[01/30/10,14:59:56] =====================================
[01/30/10,14:59:56] Pending Reboot Table state : Logging start
[01/30/10,14:59:56] _________________________________________
[01/30/10,14:59:56] There are no queued up pending reboot entries.
[01/30/10,14:59:56] Logging property values
[01/30/10,14:59:56] PROPERTY ProductName Microsoft Visual C++ 2008 Redistributable
[01/30/10,14:59:56] PROPERTY c:\baf59d10ff5f41efde0e51\vc_red.msi
[01/30/10,14:59:56] PROPERTY ProductMsi vc_red.msi
[01/30/10,14:59:56] PROPERTY Ini Filename c:\baf59d10ff5f41efde0e51\install.ini
[01/30/10,14:59:56] PROPERTY ProductCode
[01/30/10,14:59:56] PROPERTY ProductRegKey
[01/30/10,14:59:56] PROPERTY ProductRegValue
[01/30/10,14:59:56] PROPERTY ProductRegData
[01/30/10,14:59:56] PROPERTY ProductSupportURL
[01/30/10,14:59:56] PROPERTY DefaultDirInstallToken
[01/30/10,14:59:56] PROPERTY Install 0
[01/30/10,14:59:56] PROPERTY SupportWin9X 0
[01/30/10,14:59:56] PROPERTY MinNTVersion 5.0
[01/30/10,14:59:56] PROPERTY CheckAdminRights 1
[01/30/10,14:59:56] PROPERTY BlockOn64Platform
[01/30/10,14:59:56] PROPERTY ShowFeatureOptions 0
[01/30/10,14:59:56] PROPERTY ShowDestinationFolder 0
[01/30/10,14:59:56] PROPERTY LogFilePrefix dd_vcredist
[01/30/10,14:59:56] PROPERTY CustomTextPrefix CustomText
[01/30/10,14:59:56] PROPERTY MSI Log name C:\DOKUME~1\Peter\LOKALE~1\Temp\dd_vcredistMSI6FD2 .txt
[01/30/10,14:59:56] PROPERTY Msi Command Line properties
[01/30/10,14:59:56] PROPERTY VerboseLog 1
[01/30/10,14:59:56] PROPERTY RebootMode 0
[01/30/10,14:59:56] PROPERTY UILanguage 1031
[01/30/10,14:59:56] PROPERTY BitmapFile c:\baf59d10ff5f41efde0e51\vcredist.bmp
[01/30/10,14:59:56] PROPERTY User Canceled 0
[01/30/10,14:59:56] PROPERTY Red
[01/30/10,14:59:56] PROPERTY Green
[01/30/10,14:59:56] PROPERTY Blue
[01/30/10,14:59:56] PROPERTY Current Dir c:\baf59d10ff5f41efde0e51\
[01/30/10,14:59:56] PROPERTY Temp Dir C:\DOKUME~1\Peter\LOKALE~1\Temp\
[01/30/10,14:59:56] PROPERTY Usage Mode 0
[01/30/10,14:59:56] PROPERTY Admin Mode 0
[01/30/10,14:59:56] PROPERTY Maintenance Mode
[01/30/10,14:59:56] PROPERTY Silent Mode 1
[01/30/10,14:59:56] PROPERTY Silent Mode Uninstall 0
[01/30/10,14:59:56] PROPERTY WatsonSilent 0
[01/30/10,14:59:56] PROPERTY WatsonUI 0
[01/30/10,14:59:56] PROPERTY Silent Mode UI string
[01/30/10,14:59:56] PROPERTY SkipAllChecks 0
[01/30/10,14:59:56] PROPERTY WatsonGenerateManifestOnly
[01/30/10,14:59:56] PROPERTY UninstallWarning
[01/30/10,14:59:56] PROPERTY ControlMSIService
[01/30/10,14:59:56] PROPERTY RTL Language 0
[01/30/10,14:59:56] PROPERTY PostSetupCommandRegKey
[01/30/10,14:59:56] PROPERTY GlobDataINIPresent 1
[01/30/10,14:59:56] Checking Windows Installer version...
[01/30/10,14:59:56] msi.dll loaded ok
[01/30/10,14:59:56] Looking for: 2.0.0
[01/30/10,14:59:56] Found: 3.1.4000
[01/30/10,14:59:56] Windows Installer version ok
[01/30/10,14:59:56] Finished Checking Windows Installer version. Return code 0
[01/30/10,14:59:56] Entering CMsiInstaller::ThreadInit
[01/30/10,14:59:56] Leaving CMsiInstaller::ThreadInit
[01/30/10,14:59:56] Entering Silent Mode CSilentNavigator::Start
[01/30/10,14:59:56] Running all checks
[01/30/10,14:59:56] Running system checks
[01/30/10,14:59:56] SYSTEM CHECK: : One instance of setup running Passed
[01/30/10,14:59:56] SYSTEM CHECK: : Administrative rights check Passed
[01/30/10,14:59:56] SYSTEM CHECK: : Minimum NT Version 5.0 Passed
[01/30/10,14:59:56] SYSTEM CHECK: : Not runing on 9x check Passed
[01/30/10,14:59:56] Running prereq checks
[01/30/10,14:59:56] PREREQ CHECK: : Microsoft Windows Installer 2.0 Passed
[01/30/10,14:59:56] PREREQ CHECKS: Passed
[01/30/10,14:59:56] Running block checks
[01/30/10,14:59:56] BETA CHECK: Passed
[01/30/10,14:59:56] Entering CMsiInstaller::IsInstalled
[01/30/10,14:59:56] Entering CMsiInstaller::GetProductCode
[01/30/10,14:59:56] Leaving CMsiInstaller::GetProductCode
[01/30/10,14:59:56] Leaving CMsiInstaller::IsInstalled
[01/30/10,14:59:56] Entering CMsiInstaller::RegisterUIInterfaces
[01/30/10,14:59:56] Leaving CMsiInstaller::RegisterUIInterfaces
[01/30/10,14:59:56] Entering CMsiInstaller::BeginInstall
[01/30/10,15:00:26] Entering CMsiInstaller::SuppressReboot
[01/30/10,15:00:26] Leaving CMsiInstaller::SuppressReboot
[01/30/10,15:00:26] Entering CMsiInstaller::Stop
[01/30/10,15:00:26] Leaving CMsiInstaller::WorkerThread
[01/30/10,15:00:26] Leaving CMsiInstaller::Stop
[01/30/10,15:00:26] Leaving CSilentNavigator::Start
[01/30/10,15:00:26] Process returning code 1601
[01/30/10,15:00:26] Pending Reboot Table state : Logging start
[01/30/10,15:00:26] _________________________________________
[01/30/10,15:00:26] There are no queued up pending reboot entries.
[01/30/10,15:00:26] =========== Logging ended ===========
[01/30/10,15:00:26] =====================================
Code:
   FAILURE                  1601   Auf den Windows-Installationsdienst konnte
                                   nicht zugegriffen werden. Wenden Sie sich
                                   an den Support, um sicherzustellen, dass
                                   der Windows-Installationsdienst
                                   ordnungsgemäß registriert ist.
Schau mal ob der Dienst "Windows Installer" gestartet ist.
der ist unter Dienste geladen ja, aber beim Installationsversuch kommt auch folgender Fehler in der Ereignisanzeige.....
MsiInstaller
Es konnte keine Verbindung mit dem Server hergestellt werden. Fehler: 0x80080005
Ereigniskennung 1015
@pixelflat
Danke Danke Danke, das war der richtige Tip.
Der INsatller war platt
Ich habe mal neu registriert und dann ging das wieder :rulez:
c:\>Msiexec.exe /unregister
c:\>Msiexec.exe /regserver
