neue pc stürzt ab beim spielen
s4lim
Hallo lieber forum user,
hab mir ein neuen pc zusammengestellt und wollte WoW spielen aber auf einmal stürtze mein computer ab ... der computer geht ins standby und dann kommt ein lautes geräusch durch meine boxen ..
und wenn ich Battlefield2 spiel schmeissts mich nach 10 min ausm spiel raus..
grafikkarte ist es nicht weil ich x800 und hd3850 hab hab mit beiden versucht
System Information
Time of this report: 2/8/2009, 15:09:02
Machine name: S4LIM-C1LL7P6EQ
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp.080413-2111)
Language: German (Regional Setting: German)
System Manufacturer: System manufacturer
System Model: P5Q3 DELUXE
BIOS: BIOS Date: 12/11/08 12:42:39 Ver: 08.00.14
Processor: Intel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz (4 CPUs)
Memory: 2046MB RAM
Page File: 532MB used, 3406MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found. DirectDraw test results: All tests were successful. Direct3D 7 test results: The tests were cancelled before completing. Direct3D 8 test results: All tests were successful. Direct3D 9 test results: All tests were successful.
Sound Tab 1: The file ctaud2k.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer. DirectSound test results: All tests were successful.
Music Tab: DirectMusic test results: All tests were successful.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: RADEON X800 Series
Manufacturer: ATI Technologies Inc.
Chip type: ATI Radeon Graphics Processor (0x5549)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_5549&SUBSYS_04121002&REV_00
Display Memory: 256.0 MB
Current Mode: 1280 x 1024 (32 bit) (60Hz)
Monitor: Plug und Play-Monitor
Monitor Max Res: 1600,1200
Driver Name: ati2dvag.dll
Driver Version: 6.14.0010.6903 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 1/14/2009 05:47:44, 323584 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: Nicht zutreffend
Mini VDD: ati2mtag.sys
Mini VDD Date: 1/14/2009 08:14:01, 3455488 bytes
Device Identifier: {D7B71EE2-1609-11CF-4569-1824A1C2CB35}
Vendor ID: 0x1002
Device ID: 0x5549
SubSys ID: 0x04121002
Revision ID: 0x0000
Revision ID: 0x0000
Video Accel: ModeMPEG2_C ModeMPEG2_D ModeWMV8_B ModeWMV8_A ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: All tests were successful.
D3D7 Test Result: The tests were cancelled before completing.
D3D8 Test Result: All tests were successful.
D3D9 Test Result: All tests were successful.
Sound Devices
Description: SB X-Fi Audio [EC00]
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1102&DEV_0005&SUBSYS_00311102&REV_00
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: ctaud2k.sys
Driver Version: 6.00.0001.1368 (English)
WHQL Logo'd: No
Date and Size: 10/8/2008 01:21:50, 526232 bytes
Other Files:
Driver Provider: Creative
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 1, 192000
Static/Strm HW Mix Bufs: 128, 127
Static/Strm HW 3D Bufs: 128, 127
HW Memory: 0
Voice Management: Yes
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: All tests were successful.
Sound Capture Devices
Description: Logitech Mic (QuickCam E3500)
Default Sound Capture: Yes
Default Voice Capture: Yes
Driver Name: usbaudio.sys
Driver Version: 5.01.2600.5512 (English)
Date and Size: 4/13/2008 19:45:12, 60032 bytes
Cap Flags: 0x41
Format Flags: 0x0
Default Sound Capture: No
Default Voice Capture: No
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: Enabled
Ports: SB X-Fi DMusic Synth [EC00], Hardware (Kernel Mode), Output, DLS, Internal, Default Port
SB X-Fi Audio [EC00], Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI-Mapper [Emuliert], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB X-Fi Synth B [EC00] [Emuliert], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB X-Fi Synth A [EC00] [Emuliert], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emuliert], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Maus
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Tastatur
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Compaq Internet Keyboard
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x049F, 0x000E
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB-Root-Hub
| Vendor/Product ID: 0x8086, 0x3A36
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 4/13/2008 19:45:38, 59520 bytes
| Driver: usbd.sys, 8/18/2001 13:00:00, 4736 bytes
Gameport Devices
PS/2 Devices
+ HID-Tastatur
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 4/14/2008 02:58:37, 14720 bytes
| Driver: kbdclass.sys, 4/14/2008 02:58:36, 25216 bytes
+ Terminalserver-Tastaturtreiber
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 4/14/2008 03:23:26, 40840 bytes
+ HID-konforme Maus
| Vendor/Product ID: 0x046D, 0xC051
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouclass.sys, 4/14/2008 02:49:36, 23552 bytes
| Driver: mouhid.sys, 8/18/2001 13:00:00, 12288 bytes
+ Terminalserver-Maustreiber
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 TCP/IP Service Provider: LAN-Verbindung - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1,4 KBit/s
Voxware SC06 6,4 KBit/s
Voxware SC03 3,2 KBit/s
MS-PCM 64 KBit/s
MS-ADPCM 32,8 KBit/s
Microsoft GSM 6.10 13 KBit/s
TrueSpeech(TM) 8,6 KBit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 110.9 GB
Total Space: 131.1 GB
File System: NTFS
Model: ST3500320AS
Drive: D:
Model: Optiarc DVD RW AD-7203S
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.5512 (German), 4/13/2008 19:40:46, 62976 bytes
Drive: G:
Model: OBGXOZQ YVO92BKH SCSI CdRom Device
System Devices
Name: Intel(R) ICH10 Family PCI Express Root Port 6 - 3A4A
Device ID: PCI\VEN_8086&DEV_3A4A&SUBSYS_00000000&REV_00\3&11583659&0&E5
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.5512 (German), 4/14/2008 03:02:14, 68224 bytes
Name: Intel(R) ICH10 Family PCI Express Root Port 5 - 3A48
Device ID: PCI\VEN_8086&DEV_3A48&SUBSYS_00000000&REV_00\3&11583659&0&E4
Name: Intel(R) ICH10 Family PCI Express Root Port 1 - 3A40
Device ID: PCI\VEN_8086&DEV_3A40&SUBSYS_00000000&REV_00\3&11583659&0&E0
Name: Microsoft UAA-Bustreiber für High Definition Audio
Device ID: PCI\VEN_8086&DEV_3A3E&SUBSYS_83111043&REV_00\3&11583659&0&D8
Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 5.10.0001.5013 (English), 4/13/2008 17:36:05, 144384 bytes
Name: Intel(R) ICH10 Family USB Enhanced Host Controller - 3A3C
Device ID: PCI\VEN_8086&DEV_3A3C&SUBSYS_82D41043&REV_00\3&11583659&0&D7
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.5512 (English), 4/13/2008 19:45:36, 30208 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.5512 (English), 4/13/2008 19:45:36, 143872 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.5512 (German), 4/14/2008 03:22:32, 77312 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.5512 (English), 4/13/2008 19:45:38, 59520 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.5512 (English), 4/14/2008 03:22:12, 7168 bytes
Name: Intel(R) ICH10 Family USB Enhanced Host Controller - 3A3A
Device ID: PCI\VEN_8086&DEV_3A3A&SUBSYS_82D41043&REV_00\3&11583659&0&EF
Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A39
Device ID: PCI\VEN_8086&DEV_3A39&SUBSYS_82D41043&REV_00\3&11583659&0&D2
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.5512 (English), 4/13/2008 19:45:36, 20608 bytes
Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A38
Device ID: PCI\VEN_8086&DEV_3A38&SUBSYS_82D41043&REV_00\3&11583659&0&D1
Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A37
Device ID: PCI\VEN_8086&DEV_3A37&SUBSYS_82D41043&REV_00\3&11583659&0&D0
Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A36
Device ID: PCI\VEN_8086&DEV_3A36&SUBSYS_82D41043&REV_00\3&11583659&0&EA
Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A35
Device ID: PCI\VEN_8086&DEV_3A35&SUBSYS_82D41043&REV_00\3&11583659&0&E9
Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A34
Device ID: PCI\VEN_8086&DEV_3A34&SUBSYS_82D41043&REV_00\3&11583659&0&E8
Name: Intel(R) ICH10 Family SMBus Controller - 3A30
Device ID: PCI\VEN_8086&DEV_3A30&SUBSYS_82D41043&REV_00\3&11583659&0&FB
Driver: n/a
Name: Intel(R) ICH10 Family 2 port Serial ATA Storage Controller 2 - 3A26
Device ID: PCI\VEN_8086&DEV_3A26&SUBSYS_82D41043&REV_00\3&11583659&0&FD
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (German), 8/18/2001 04:30:42, 3328 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.5512 (German), 4/13/2008 19:40:30, 24960 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.5512 (English), 4/13/2008 19:40:30, 96512 bytes
Name: Intel(R) ICH10 Family 4 port Serial ATA Storage Controller 1 - 3A20
Device ID: PCI\VEN_8086&DEV_3A20&SUBSYS_82D41043&REV_00\3&11583659&0&FA
Name: Intel(R) ICH10R LPC Interface Controller - 3A16
Device ID: PCI\VEN_8086&DEV_3A16&SUBSYS_00000000&REV_00\3&11583659&0&F8
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.5512 (German), 4/14/2008 02:58:04, 37632 bytes
Name: Intel(R) 4 Series Chipset PCI Express Root Port - 2E21
Device ID: PCI\VEN_8086&DEV_2E21&SUBSYS_00000000&REV_02\3&11583659&0&08
Name: Intel(R) 4 Series Chipset Processor to I/O Controller - 2E20
Device ID: PCI\VEN_8086&DEV_2E20&SUBSYS_00000000&REV_02\3&11583659&0&00
Driver: n/a
Name: Intel(R) 82801BA/CA PCI-Brücke - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_90\3&11583659&0&F0
Driver: n/a
Name: OHCI-konformer IEEE 1394-Hostcontroller
Device ID: PCI\VEN_11C1&DEV_5811&SUBSYS_82941043&REV_70\4&31B6CD7&0&18F0
Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.5512 (English), 4/13/2008 19:46:18, 61696 bytes
Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.5512 (English), 4/13/2008 19:46:18, 53376 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.5512 (English), 4/13/2008 19:51:25, 61824 bytes
Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.5512 (English), 4/13/2008 19:51:25, 60800 bytes
Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 13:46:40, 6400 bytes
Name: Marvell 61xx RAID Controller
Device ID: PCI\VEN_11AB&DEV_6121&SUBSYS_82121043&REV_B1\4&34EBACD6&0&00E4
Driver: C:\WINDOWS\system32\DRIVERS\mv61xx.sys, 1.02.0000.0055 (English), 5/19/2008 08:46:30, 150568 bytes
Name: Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller
Device ID: PCI\VEN_11AB&DEV_4364&SUBSYS_81F81043&REV_12\4&20515DB1&0&00E5
Driver: n/a
Name: Marvell Yukon 88E8001/8003/8010 PCI Gigabit Ethernet Controller
Device ID: PCI\VEN_11AB&DEV_4320&SUBSYS_811A1043&REV_14\4&31B6CD7&0&10F0
Driver: n/a
Name: Creative SB X-Fi
Device ID: PCI\VEN_1102&DEV_0005&SUBSYS_00311102&REV_00\4&31B6CD7&0&08F0
Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.5512 (German), 4/14/2008 03:22:14, 4096 bytes
Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.5512 (German), 4/14/2008 03:23:08, 129536 bytes
Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.5512 (German), 4/13/2008 20:16:36, 141056 bytes
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.5512 (English), 4/13/2008 19:45:14, 60160 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.5512 (English), 4/13/2008 20:19:42, 146048 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.5512 (German), 4/13/2008 19:45:16, 49408 bytes
Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.5512 (English), 4/14/2008 03:23:08, 23552 bytes
Driver: C:\WINDOWS\system32\drivers\ctac32k.sys, 6.00.0001.1361 (English), 10/8/2008 01:21:46, 511000 bytes
Driver: C:\WINDOWS\system32\drivers\ctaud2k.sys, 6.00.0001.1368 (English), 10/8/2008 01:21:50, 526232 bytes
Driver: C:\WINDOWS\system32\drivers\ctoss2k.sys, 6.00.0001.1368 (English), 10/8/2008 01:21:56, 130072 bytes
Driver: C:\WINDOWS\system32\drivers\ctprxy2k.sys, 6.00.0001.1368 (English), 10/8/2008 01:21:58, 14360 bytes
Driver: C:\WINDOWS\system32\drivers\ctsfm2k.sys, 6.00.0001.1368 (English), 10/8/2008 01:22:00, 158744 bytes
Driver: C:\WINDOWS\system32\drivers\emupia2k.sys, 6.00.0001.1368 (English), 10/8/2008 01:22:02, 95768 bytes
Driver: C:\WINDOWS\system32\drivers\ha20x2k.sys, 6.00.0001.1368 (English), 10/8/2008 01:22:04, 1177624 bytes
Driver: C:\WINDOWS\system32\drivers\pfmodnt.sys, 3.00.0000.0012 (English), 10/8/2008 01:22:06, 15384 bytes
Driver: C:\WINDOWS\system32\drivers\CTEXFIFX.sys, 6.00.0001.1368 (English), 10/8/2008 01:21:44, 1324056 bytes
Driver: C:\WINDOWS\system32\drivers\CT20XUT.sys, 6.00.0001.1368 (English), 10/8/2008 01:21:38, 171032 bytes
Driver: C:\WINDOWS\system32\drivers\CTHWIUT.sys, 6.00.0001.1368 (English), 10/8/2008 01:21:40, 72728 bytes
Driver: C:\WINDOWS\system32\ctdlang.dat, 10/7/2008 23:31:14, 321512 bytes
Driver: C:\WINDOWS\system32\ctdnlstr.dat, 10/7/2008 23:31:14, 56509 bytes
Driver: C:\WINDOWS\system32\CtxfiRes.dll, 6.00.0001.1368 (English), 10/7/2008 23:41:40, 2560 bytes
Driver: C:\WINDOWS\system32\ctzapxx.ini, 9/12/2008 21:22:40, 54 bytes
Driver: C:\WINDOWS\system32\instwdm.ini, 10/8/2008 00:08:38, 20936 bytes
Driver: C:\WINDOWS\system32\CT1MGM.ROM, 2/25/2000 12:49:34, 1048576 bytes
Driver: C:\WINDOWS\system32\CT2MGM.SF2, 9/22/1999 23:18:38, 2167684 bytes
Driver: C:\WINDOWS\system32\default4.sfm, 1/3/2002 15:44:16, 59 bytes
Driver: C:\WINDOWS\system32\default8.sfm, 1/3/2002 15:44:16, 59 bytes
Driver: C:\WINDOWS\system32\default.sfm, 1/3/2002 15:44:16, 59 bytes
Driver: C:\WINDOWS\Temp\ctpxst32.exe, 1.01.0000.0059 (English), 3/13/2007 10:32:14, 89336 bytes
Driver: C:\WINDOWS\Temp\cttele32.dll, 1.00.0011.0000 (English), 2/4/2008 10:27:58, 102400 bytes
Driver: C:\WINDOWS\system32\regplib.exe, 10/7/2008 23:26:38, 16384 bytes
Driver: C:\WINDOWS\system32\a3d.dll, 80.00.0000.0003 (English), 10/7/2008 23:42:42, 60928 bytes
Driver: C:\WINDOWS\system32\ac3api.dll, 6.00.0001.1368 (English), 10/7/2008 23:42:16, 48640 bytes
Driver: C:\WINDOWS\system32\eaxac3.dll, 1.01.0002.0000 (English), 7/11/2001 10:51:00, 77824 bytes
Driver: C:\WINDOWS\system32\ctosuser.dll, 6.00.0001.1368 (English), 10/7/2008 23:26:44, 74752 bytes
Driver: C:\WINDOWS\system32\ctemupia.dll, 6.00.0001.1368 (English), 10/7/2008 23:30:32, 114688 bytes
Driver: C:\WINDOWS\system32\piaproxy.dll, 6.00.0001.1368 (English), 10/7/2008 23:26:36, 68608 bytes
Driver: C:\WINDOWS\system32\ctdproxy.dll, 6.00.0001.1368 (English), 10/7/2008 23:27:26, 53248 bytes
Driver: C:\WINDOWS\system32\devreg.dll, 6.00.0001.1368 (English), 10/7/2008 23:23:26, 36864 bytes
Driver: C:\WINDOWS\system32\ctasio.dll, 6.00.0001.1368 (English), 10/7/2008 23:27:32, 50688 bytes
Driver: C:\WINDOWS\system32\ct_oal.dll, 6.00.0001.1368 (English), 10/7/2008 23:27:36, 193024 bytes
Driver: C:\WINDOWS\system32\ctpxst32.exe, 1.01.0000.0059 (English), 3/13/2007 10:32:14, 89336 bytes
Driver: C:\WINDOWS\system32\APOIM32.exe, 2.29.0000.0000 (English), 7/18/2008 09:39:18, 595249 bytes
Driver: C:\WINDOWS\system32\oalinst.exe, 2.00.0006.0000 (English), 4/23/2008 06:07:50, 805400 bytes
Driver: C:\WINDOWS\system32\AddCat.exe, 0.00.0000.0001 (English), 12/5/2006 14:52:40, 48400 bytes
Driver: C:\WINDOWS\system32\CTAPO32.UDA, 8/21/2008 15:32:36, 7954 bytes
Driver: C:\WINDOWS\system32\CTMLFX32.UDA, 6/2/2008 11:10:04, 5458 bytes
Driver: C:\WINDOWS\system32\AppSetup.exe, 1.00.0000.0018 (English), 9/25/2008 15:40:32, 20888640 bytes
Driver: C:\WINDOWS\system32\CTxfiBtn.dll, 6.00.0001.1368 (English), 10/7/2008 23:41:38, 41472 bytes
Driver: C:\WINDOWS\system32\CTxfiSpk.dll, 6.00.0001.1368 (English), 10/7/2008 23:41:38, 39424 bytes
Driver: C:\WINDOWS\system32\Ct20xspi.dll, 6.00.0001.1368 (English), 10/7/2008 23:37:44, 15360 bytes
Driver: C:\WINDOWS\system32\CTxfispi.exe, 6.00.0001.1368 (English), 10/7/2008 23:37:38, 1212928 bytes
Driver: C:\WINDOWS\system32\Ctxfihlp.exe, 6.00.0001.1368 (English), 10/7/2008 23:41:36, 23552 bytes
Driver: C:\WINDOWS\system32\CTxfiReg.exe, 6.00.0001.1368 (English), 10/7/2008 23:37:46, 47104 bytes
Driver: C:\WINDOWS\system32\enlocstr.exe, 10/7/2008 23:23:50, 7680 bytes
Driver: C:\WINDOWS\system32\killapps.exe, 1.00.0000.0001 (English), 10/7/2008 23:23:46, 12800 bytes
Driver: C:\WINDOWS\system32\kill.ini, 8/19/2008 18:39:18, 321 bytes
Driver: C:\WINDOWS\system32\sfman32.dll, 6.00.0001.1368 (English), 10/7/2008 23:26:44, 10240 bytes
Driver: C:\WINDOWS\system32\sfms32.dll, 6.00.0001.1368 (English), 10/7/2008 23:26:42, 108544 bytes
Driver: C:\WINDOWS\system32\data\cts20x.dat, 10/7/2008 23:23:52, 2091 bytes
Driver: C:\WINDOWS\system32\data\ctd20x.dat, 10/7/2008 23:23:52, 26919 bytes
Driver: C:\WINDOWS\system32\data\CTP0460W.DAT, 10/7/2008 23:26:14, 275836 bytes
Driver: C:\WINDOWS\system32\data\CTP0466W.DAT, 10/7/2008 23:26:14, 275836 bytes
Driver: C:\WINDOWS\system32\data\CTP0463W.DAT, 10/7/2008 23:26:14, 276282 bytes
Driver: C:\WINDOWS\system32\data\CTP0550W.DAT, 10/7/2008 23:26:14, 276094 bytes
Driver: C:\WINDOWS\system32\data\CTP0678W.DAT, 10/7/2008 23:26:20, 357983 bytes
Driver: C:\WINDOWS\system32\data\CTP0679W.DAT, 10/7/2008 23:26:14, 357983 bytes
Driver: C:\WINDOWS\system32\data\CTP0464W.DAT, 10/7/2008 23:26:14, 275836 bytes
Driver: C:\WINDOWS\system32\data\CTP0468W.DAT, 10/7/2008 23:26:16, 275836 bytes
Driver: C:\WINDOWS\system32\data\CTP0465W.DAT, 10/7/2008 23:26:16, 275836 bytes
Driver: C:\WINDOWS\system32\data\CTP0469W.DAT, 10/7/2008 23:26:16, 275836 bytes
Driver: C:\WINDOWS\system32\data\CTP0730W.DAT, 10/7/2008 23:26:16, 277688 bytes
Driver: C:\WINDOWS\system32\data\CTP0760W.DAT, 10/7/2008 23:26:16, 275257 bytes
Driver: C:\WINDOWS\system32\data\CTP046AW.DAT, 10/7/2008 23:26:16, 275508 bytes
Driver: C:\WINDOWS\system32\data\CTP046BW.DAT, 10/7/2008 23:26:16, 275508 bytes
Driver: C:\WINDOWS\system32\data\CTP046CW.DAT, 10/7/2008 23:26:16, 275508 bytes
Driver: C:\WINDOWS\system32\data\CTP0462W.DAT, 10/7/2008 23:26:18, 275836 bytes
Driver: C:\WINDOWS\system32\data\CTP055AW.DAT, 10/7/2008 23:26:18, 275766 bytes
Driver: C:\WINDOWS\system32\data\CTP073AW.DAT, 10/7/2008 23:26:18, 277688 bytes
Driver: C:\WINDOWS\system32\data\CTXFIGM.RFX, 7/28/2006 10:31:42, 41320 bytes
Driver: C:\WINDOWS\system32\data\CTXFIEM.RFX, 7/28/2006 10:31:40, 41788 bytes
Driver: C:\WINDOWS\system32\data\CTXFICM.RFX, 7/28/2006 10:31:38, 41624 bytes
Driver: C:\WINDOWS\system32\data\CTXFICBM.RFX, 6/23/2005 06:58:50, 7352 bytes
Driver: C:\WINDOWS\system32\SBXFi.ico, 2/7/2005 17:45:22, 766 bytes
Driver: C:\WINDOWS\system32\XFi.bmp, 2/7/2005 17:45:20, 3128 bytes
Driver: C:\WINDOWS\system32\ctcoinst.dll, 3.00.0002.0047 (English), 10/7/2008 23:44:28, 86016 bytes
Driver: C:\WINDOWS\system32\ctdvinst.dll, 0.05.0000.0047 (English), 10/7/2008 23:44:28, 181248 bytes
Driver: C:\WINDOWS\system32\drivers\ctdvda2k.sys, 5.13.0001.0468 (English), 10/8/2008 01:21:54, 347080 bytes
Name: RADEON X800 PRO Secondary
Device ID: PCI\VEN_1002&DEV_5569&SUBSYS_04131002&REV_00\4&22FC202A&0&0108
Driver: C:\WINDOWS\system32\DRIVERS\ati2mtag.sys, 6.14.0010.6903 (German), 1/14/2009 08:14:01, 3455488 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ati2erec.dll, 1.00.0000.0016 (English), 1/14/2009 04:43:12, 53248 bytes
Driver: C:\WINDOWS\system32\ati2dvag.dll, 6.14.0010.6903 (English), 1/14/2009 05:47:44, 323584 bytes
Driver: C:\WINDOWS\system32\ati2cqag.dll, 6.14.0010.0407 (English), 1/14/2009 04:37:08, 577536 bytes
Driver: C:\WINDOWS\system32\Ati2mdxx.exe, 6.14.0010.2495 (English), 1/14/2009 05:36:06, 26112 bytes
Driver: C:\WINDOWS\system32\ati3duag.dll, 6.14.0010.0636 (English), 1/14/2009 05:22:33, 4009152 bytes
Driver: C:\WINDOWS\system32\ativvaxx.dll, 6.14.0010.0211 (English), 1/14/2009 05:05:42, 2500224 bytes
Driver: C:\WINDOWS\system32\atiicdxx.dat, 10/29/2008 23:13:33, 180720 bytes
Driver: C:\WINDOWS\system32\ativvaxx.dat, 1/14/2009 05:05:09, 3107788 bytes
Driver: C:\WINDOWS\system32\ativva5x.dat, 1/14/2009 05:05:09, 3107788 bytes
Driver: C:\WINDOWS\system32\ativva6x.dat, 1/14/2009 05:05:09, 887724 bytes
Driver: C:\WINDOWS\system32\amdpcom32.dll, 6.14.0010.0019 (English), 1/14/2009 04:50:08, 48640 bytes
Driver: C:\WINDOWS\system32\atiadlxx.dll, 6.14.0010.1023 (English), 1/14/2009 04:44:17, 110592 bytes
Driver: C:\WINDOWS\system32\ativvaxx.cap, 1/14/2009 05:05:09, 79008 bytes
Driver: C:\WINDOWS\system32\ATIDDC.DLL, 6.14.0010.0008 (English), 1/14/2009 05:32:31, 53248 bytes
Driver: C:\WINDOWS\system32\atitvo32.dll, 6.14.0010.4200 (English), 1/14/2009 04:44:05, 17408 bytes
Driver: C:\WINDOWS\system32\ativcoxx.dll, 6.13.0010.0005 (English), 11/9/2001 17:01:04, 24064 bytes
Driver: C:\WINDOWS\system32\ati2evxx.exe, 6.14.0010.4218 (English), 1/14/2009 05:34:00, 598016 bytes
Driver: C:\WINDOWS\system32\ati2evxx.dll, 6.14.0010.4177 (English), 1/14/2009 05:35:38, 155648 bytes
Driver: C:\WINDOWS\system32\atipdlxx.dll, 6.14.0010.2545 (English), 1/14/2009 05:36:29, 196608 bytes
Driver: C:\WINDOWS\system32\Oemdspif.dll, 6.15.0006.0001 (English), 1/14/2009 05:36:15, 151552 bytes
Driver: C:\WINDOWS\system32\ati2edxx.dll, 6.14.0010.2513 (English), 1/14/2009 05:35:56, 43520 bytes
Driver: C:\WINDOWS\system32\atikvmag.dll, 6.14.0010.0093 (German), 1/14/2009 04:45:52, 401408 bytes
Driver: C:\WINDOWS\system32\atifglpf.xml, 8/31/2007 15:20:49, 7167 bytes
Driver: C:\WINDOWS\system32\ATIDEMGX.dll, 2.00.3300.42872 (German), 1/14/2009 05:49:05, 425984 bytes
Driver: C:\WINDOWS\system32\Amdcaldd.dll, 6.14.0010.0158 (English), 1/14/2009 03:34:00, 3227648 bytes
Driver: C:\WINDOWS\system32\amdcalrt.dll, 6.14.0010.0158 (English), 1/14/2009 03:36:37, 45056 bytes
Driver: C:\WINDOWS\system32\amdcalcl.dll, 6.14.0010.0158 (English), 1/14/2009 03:36:30, 45056 bytes
Driver: C:\WINDOWS\system32\atibrtmon.exe, 2.00.0000.0000 (English), 10/21/2008 19:51:43, 118784 bytes
Driver: C:\WINDOWS\system32\atiok3x2.dll, 6.14.0010.8395 (German), 1/14/2009 05:53:11, 286720 bytes
Driver: C:\WINDOWS\system32\atioglxx.dll, 6.14.0010.8395 (English), 1/14/2009 06:46:13, 11591680 bytes
Driver: C:\WINDOWS\system32\atiiiexx.dll, 6.14.0010.4006 (English), 1/14/2009 04:37:45, 307200 bytes
Driver: C:\WINDOWS\atiogl.xml, 11/21/2008 04:26:10, 15362 bytes
Name: RADEON X800 Series
Device ID: PCI\VEN_1002&DEV_5549&SUBSYS_04121002&REV_00\4&22FC202A&0&0008
DirectX Components
ddraw.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:08 279552 bytes
ddrawex.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:08 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/18/2001 13:00:00 10496 bytes
d3d8.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:08 1179648 bytes
d3d8thk.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:08 8192 bytes
d3d9.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:08 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/18/2001 13:00:00 436224 bytes
d3dim700.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:08 824320 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/18/2001 13:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/18/2001 13:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/18/2001 13:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/18/2001 13:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 German Final Retail 8/18/2001 13:00:00 33040 bytes
dplayx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:09 229888 bytes
dpmodemx.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:09 24064 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/18/2001 13:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:09 57856 bytes
dplaysvr.exe: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:43 29696 bytes
dpnsvr.exe: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:43 17920 bytes
dpnet.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:09 375296 bytes
dpnlobby.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:20:27 3072 bytes
dpnaddr.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:20:27 3072 bytes
dpvoice.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:09 214016 bytes
dpvsetup.exe: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:43 83456 bytes
dpvvox.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:09 116736 bytes
dpvacm.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:09 21504 bytes
dpnhpast.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:09 35328 bytes
dpnhupnp.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:09 60928 bytes
dpserial.dll: 5.00.2134.0001 German Final Retail 8/18/2001 13:00:00 54032 bytes
dinput.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:09 163328 bytes
dinput8.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:09 186368 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/18/2001 13:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 German Final Retail 8/18/2001 13:00:00 395264 bytes
joy.cpl: 5.03.2600.5512 German Final Retail 4/14/2008 03:23:07 69632 bytes
gcdef.dll: 5.01.2600.0000 German Final Retail 8/18/2001 13:00:00 78336 bytes
pid.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:23 35328 bytes
dsound.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:09 367616 bytes
dsound3d.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:09 1293824 bytes
dswave.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:09 19456 bytes
dsdmo.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:09 181248 bytes
dsdmoprp.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:09 74240 bytes
dmusic.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:09 104448 bytes
dmband.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:09 28672 bytes
dmcompos.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:09 61440 bytes
dmime.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:09 181248 bytes
dmloader.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:09 35840 bytes
dmstyle.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:09 105984 bytes
dmsynth.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:09 103424 bytes
dmscript.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:09 82432 bytes
Microsoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 2/6/2009 21:58:46 473600 bytes
Microsoft.DirectX.Direct3DX.dll: 9.06.0168.0000 English Final Retail 2/6/2009 21:58:46 567296 bytes
Microsoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 2/6/2009 21:58:46 145920 bytes
Microsoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 2/6/2009 21:58:46 159232 bytes
Microsoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 2/6/2009 21:58:46 364544 bytes
Microsoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 2/6/2009 21:58:46 178176 bytes
Microsoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 2/6/2009 21:58:45 53248 bytes
Microsoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 2/6/2009 21:58:45 12800 bytes
Microsoft.DirectX.dll: 5.04.0000.2904 English Final Retail 2/6/2009 21:58:45 223232 bytes
dx7vb.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:09 619008 bytes
dx8vb.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:09 1227264 bytes
dxdiagn.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:09 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/18/2001 13:00:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 4/14/2008 03:22:14 1028096 bytes
wsock32.dll: 5.01.2600.5512 German Final Retail 4/14/2008 03:22:32 24576 bytes
amstream.dll: 6.05.2600.5512 English Final Retail 4/14/2008 03:22:07 70656 bytes
devenum.dll: 6.05.2600.5512 German Final Retail 4/14/2008 03:22:08 59904 bytes
dxmasf.dll: 6.04.0009.1133 German Final Retail 4/14/2008 03:22:09 500278 bytes
mciqtz32.dll: 6.05.2600.5512 German Final Retail 4/14/2008 03:22:14 35328 bytes
mpg2splt.ax: 6.05.2600.5512 English Final Retail 4/14/2008 03:23:07 148992 bytes
msdmo.dll: 6.05.2600.5512 English Final Retail 4/14/2008 03:22:16 14336 bytes
encapi.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:10 20480 bytes
qasf.dll: 9.00.0000.4503 German Final Retail 4/14/2008 03:22:23 237568 bytes
qcap.dll: 6.05.2600.5512 German Final Retail 4/14/2008 03:22:23 192512 bytes
qdv.dll: 6.05.2600.5512 German Final Retail 4/14/2008 03:22:23 279040 bytes
qdvd.dll: 6.05.2600.5512 German Final Retail 4/14/2008 03:22:23 387072 bytes
qedit.dll: 6.05.2600.5512 German Final Retail 4/14/2008 03:22:23 563200 bytes
qedwipes.dll: 6.05.2600.5512 English Final Retail 4/13/2008 18:21:32 733696 bytes
quartz.dll: 6.05.2600.5512 German Final Retail 4/14/2008 03:22:23 1293824 bytes
strmdll.dll: 4.01.0000.3936 German Final Retail 4/14/2008 03:22:30 246814 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 4/14/2008 03:23:07 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 4/14/2008 03:23:07 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 4/14/2008 03:22:12 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 4/14/2008 03:22:12 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 4/14/2008 03:22:12 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 4/14/2008 03:22:12 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 4/14/2008 03:22:12 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 4/14/2008 03:23:07 154624 bytes
mswebdvd.dll: 6.05.2600.5512 German Final Retail 4/14/2008 03:22:18 205312 bytes
ks.sys: 5.03.2600.5512 German Final Retail 4/13/2008 20:16:36 141056 bytes
ksproxy.ax: 5.03.2600.5512 German Final Retail 4/14/2008 03:23:08 129536 bytes
ksuser.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:14 4096 bytes
stream.sys: 5.03.2600.5512 German Final Retail 4/13/2008 19:45:16 49408 bytes
mspclock.sys: 5.03.2600.5512 German Final Retail 4/13/2008 19:39:50 5376 bytes
mspqm.sys: 5.01.2600.5512 German Final Retail 4/13/2008 19:39:52 4992 bytes
mskssrv.sys: 5.03.2600.5512 German Final Retail 4/13/2008 19:39:52 7552 bytes
swenum.sys: 5.03.2600.5512 German Final Retail 4/13/2008 19:39:53 4352 bytes
mstee.sys: 5.03.2600.5512 German Final Retail 4/13/2008 19:39:50 5504 bytes
ipsink.ax: 5.03.2600.5512 German Final Retail 4/14/2008 03:23:08 16384 bytes
mpeg2data.ax: 6.05.2600.5512 English Final Retail 4/14/2008 03:23:07 118272 bytes
ndisip.sys: 5.03.2600.5512 English Final Retail 4/13/2008 19:46:22 10880 bytes
streamip.sys: 5.03.2600.5512 English Final Retail 4/13/2008 19:46:22 15232 bytes
msvidctl.dll: 6.05.2600.5512 German Final Retail 4/14/2008 03:22:18 1433088 bytes
slip.sys: 5.03.2600.5512 English Final Retail 4/13/2008 19:46:24 11136 bytes
nabtsfec.sys: 5.03.2600.5512 English Final Retail 4/13/2008 19:46:26 85248 bytes
ccdecode.sys: 5.03.2600.5512 English Final Retail 4/13/2008 19:46:24 17024 bytes
vbisurf.ax: 5.03.2600.5512 English Final Retail 4/14/2008 03:23:07 30208 bytes
msyuv.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:18 16896 bytes
kstvtune.ax: 5.03.2600.5512 German Final Retail 4/14/2008 03:23:08 61952 bytes
ksxbar.ax: 5.03.2600.5512 English Final Retail 4/14/2008 03:23:08 43008 bytes
kswdmcap.ax: 5.03.2600.5512 German Final Retail 4/14/2008 03:23:08 91648 bytes
vfwwdm32.dll: 5.01.2600.5512 German Final Retail 4/14/2008 03:22:32 54272 bytes
wstcodec.sys: 5.03.2600.5512 English Final Retail 4/13/2008 19:46:24 19200 bytes
wstdecod.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:32 51200 bytes
DirectShow Filters
WDM Streaming-VBI-Codecs:
NABTS/FEC VBI-Codec,0x00200000,2,1,,5.03.2600.5512
Untertiteldecoder,0x00200000,2,1,,5.03.2600.5512
WST-Codec,0x00200000,1,1,,5.03.2600.5512
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.5512
WMT VIH2 Fix,0x00200000,1,1,WLXVAFilt.dll,14.00.8051.1204
Record Queue,0x00200000,1,1,WLXVAFilt.dll,14.00.8051.1204
WMT Switch Filter,0x00200000,1,1,WLXVAFilt.dll,14.00.8051.1204
WMT Virtual Renderer,0x00200000,1,0,WLXVAFilt.dll,14.00.8051.1204
WMT DV Extract,0x00200000,1,1,WLXVAFilt.dll,14.00.8051.1204
WMT Virtual Source,0x00200000,0,1,WLXVAFilt.dll,14.00.8051.1204
WMT Sample Information Filter,0x00200000,1,1,WLXVAFilt.dll,14.00.8051.1204
ATI Ticker,0x00200000,0,1,Ticker.ax,
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.5512
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.5512
WM ASF Reader,0x00400000,0,0,qasf.dll,9.00.0000.4503
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.5512
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.5512
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5512
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.5512
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.5512
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.5512
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.5512
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.5512
MMACE ProcAmp,0x00200000,0,2,MMACEFilters.dll,
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,9.00.0000.4503
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.5512
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASX file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.4503
NSC file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.5512
Windows Media source filter,0x00600000,0,2,wmpasf.dll,9.00.0000.4503
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.5512
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.5512
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.5512
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.5512
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.5512
File Writer,0x00200000,1,0,WLXVAFilt.dll,14.00.8051.1204
WM ASF Writer,0x00400000,0,0,qasf.dll,9.00.0000.4503
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.5512
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
MMACE SoftEmu,0x00200000,0,2,MMACEFilters.dll,
File writer,0x00200000,1,0,qcap.dll,6.05.2600.5512
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.5512
MMACE DeInterlace,0x00200000,0,2,MMACEFilters.dll,
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.5512
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.5512
.RAM file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.4503
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.5512
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,9.00.0000.4503
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF URL Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.5512
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.5512
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,
IVF source filter,0x00600000,0,1,ivfsrc.ax,5.10.0002.0051
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.5512
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.5512
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5512
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.5512
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.5512
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.5512
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.5512
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.5512
Lyric Parser,0x00400000,1,1,quartz.dll,6.05.2600.5512
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.5512
XML Playlist,0x00400000,1,0,wmpasf.dll,9.00.0000.4503
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.5512
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.5512
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.5512
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.5512
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Pad VU Data Grabber,0x00600000,1,0,wmmfilt.dll,1.01.2427.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.5512
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5512
ShotBoundaryDet,0x00200000,1,1,wmmfilt.dll,1.01.2427.0000
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.5512
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming-Tee/Splitter-Geräte:
Tee/Sink-to-Sink-Konvertierung,0x00200000,1,1,,5.03.2600.5512
WDM Streaming-Daten-Transforms:
Microsoft Kernel-Echounterdrückung,0x00000000,0,0,,
Microsoft Kernel GS Wavetablesynthesizer,0x00200000,1,1,,5.03.2600.5512
Microsoft Kernel-DLS-Synthesizer,0x00200000,1,1,,5.03.2600.5512
Microsoft Kernel-DRM-Audioentschlüsselung,0x00200000,1,1,,5.03.2600.5512
Video Compressors:
WMVideo Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.5512
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.5512
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.5512
Logitech Video (I420),0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.5512
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel IYUV Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.5512
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.5512
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.5512
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.5512
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.5512
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.5512
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.5512
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.5512
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.5512
Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.05.2600.5512
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.5512
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.5512
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.5512
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.5512
Audio Capture Sources:
Logitech Mic (QuickCam E3500),0x00200000,0,0,qcap.dll,6.05.2600.5512
SB X-Fi Audio [EC00],0x00200000,0,0,qcap.dll,6.05.2600.5512
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.5512
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.5512
SB X-Fi Synth A [EC00],0x00200000,1,0,quartz.dll,6.05.2600.5512
SB X-Fi Synth B [EC00],0x00200000,1,0,quartz.dll,6.05.2600.5512
WDM Streaming-Capturegeräte:
SB X-Fi Audio [EC00],0x00200000,3,2,,5.03.2600.5512
Logitech QuickCam E3500,0x00200000,3,0,,5.03.2600.5512
Logitech Mic (QuickCam E3500),0x00200000,1,1,,5.03.2600.5512
WDM Streaming-Wiedergabegeräte:
SB X-Fi DMusic Synth [EC00],0x00200000,1,1,,5.03.2600.5512
SB X-Fi Synth A [EC00],0x00200000,1,1,,5.03.2600.5512
SB X-Fi Synth B [EC00],0x00200000,1,1,,5.03.2600.5512
BDA-Wiedergabefilter:
BDA-IP-Sink,0x00200000,1,1,,5.03.2600.5512
Video Capture Sources:
BDA Transport Information Renderers:
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,
WDM Streaming-Mixer:
Microsoft Kernel-Waveaudiomixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,
Encrypt/Tag,0x00200000,0,0,encdec.dll,
XDS Codec,0x00200000,0,0,encdec.dll,
WDM Streaming-Kommunikations-Transforms:
Audio Renderers:
SB X-Fi Audio [EC00],0x00200000,1,0,quartz.dll,6.05.2600.5512
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.5512
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.5512
DirectSound: SB X-Fi Audio [EC00],0x00200000,1,0,quartz.dll,6.05.2600.5512
WDM Streaming-Systemgeräte:
SB X-Fi Synth A [EC00],0x00200000,7,2,,5.03.2600.5512
SB X-Fi Audio [EC00],0x00200000,9,2,,5.03.2600.5512
BDA-Empfängerkomponenten:
BDA Slip De-Framer,0x00600000,1,1,,5.03.2600.5512
Hallo und wilkommen bei PCMasters!
Wie siehts denn bei deinem Rechner mit den Temperaturen (unter Last) aus? Ich tippe jetzt erstmal darauf, da sich das Problem danach anhört...
Mit freundlichen Grüßen
SoftAir Booster
danke softair booster temperatueren sind bissl hoch aber trotzdem aktzeptabel cpu 40-60 gpu 55-75
ati test tool hab ich rennen lassen waren keine fehler soweit ich es gesehn hab. memory test hab ich auch gemacht war auch kein fehler...
Memory: 2046MB RAM XMS DDR3
Netzteil: Enermax 500watt
Mainboard: p5q3 delux wifi
eins muss ich dazu sagen ich hab 3 mal mein mainboard wechseln müssen weil alle ein produktionsfehler waren
1.st p5q-e sata und chip fehler
2.Intel d45sg lasst sich nicht einschalten
3.p5q3 "?"
4.Ram war defekt
es waren alles produktionsfehler wenn das auch eine fehlschlag wird dann hab ich keine hoffnung mehr... 🙁
ihr könnts sicher vorstellen wie geärgert ich bin ^^ bin mind 8 mal 100km mit zug gefahren wegen die ganzen hardware 🙁
Mit ATITool kannst du nur die Grafikkarte auslasten. Zudem wirkt das auch nur bei älteren Karten, die neuen gääääähnen davon... 😉
Lass mal Prime95 ( ) laufen und les nach 5-10 Minuten die CPU (Core-)Temperaturen aus.
