Passen diese Elemente Zusammen?
traced
[FONT=Century Gothic, sans-serif]Gehäuse:[/FONT]
[FONT=Century Gothic, sans-serif]Antec P182 (black) [/FONT]
[FONT=Century Gothic, sans-serif]Internet 116€[/FONT]
[FONT=Century Gothic, sans-serif]Mainboard:[/FONT]
[FONT=Century Gothic, sans-serif]Gigabyte P35-DS3P[/FONT]
[FONT=Century Gothic, sans-serif]PCGH 130€ Internet 124€[/FONT]
[FONT=Century Gothic, sans-serif]Prozessor:[/FONT]
[FONT=Century Gothic, sans-serif]Core 2 Duo E6700 [/FONT]
[FONT=Century Gothic, sans-serif]PCGH 275€ Internet 257€[/FONT]
[FONT=Century Gothic, sans-serif]oder[/FONT]
[FONT=Century Gothic, sans-serif]Core 2 Duo E6600 [/FONT]
[FONT=Century Gothic, sans-serif]PCGH 190€ Internet 184€[/FONT]
[FONT=Century Gothic, sans-serif]Prozessorkühler:[/FONT]
[FONT=Century Gothic, sans-serif]Zalman CNPS 9700 LED[/FONT]
[FONT=Century Gothic, sans-serif]Internet 44€[/FONT]
[FONT=Century Gothic, sans-serif]Arbeitsspeicher:[/FONT]
[FONT=Century Gothic, sans-serif]Corsair DDR2-800 4.0gb Kit[/FONT]
[FONT=Century Gothic, sans-serif]Gamestar 260€ Internet 239€[/FONT]
[FONT=Century Gothic, sans-serif]Grafikkarte:[/FONT]
[FONT=Century Gothic, sans-serif]MSI NX8800GTX / 768 MB [/FONT]
[FONT=Century Gothic, sans-serif]Gamestar 540€ [/FONT]
[FONT=Century Gothic, sans-serif]Oder [/FONT]
[FONT=Century Gothic, sans-serif]Asus EN8800GTX[/FONT]
[FONT=Century Gothic, sans-serif]PCGH 490€ Internet 476[/FONT]
[FONT=Century Gothic, sans-serif]Festplatten:[/FONT]
[FONT=Century Gothic, sans-serif]2x Samsung spinpoint T HD501LJ[/FONT]
[FONT=Century Gothic, sans-serif]PCGH 90€ ~180€Internet 86 ~172€[/FONT]
[FONT=Century Gothic, sans-serif]Netzteil:[/FONT]
[FONT=Century Gothic, sans-serif]Seasonic M12 ss -500[/FONT]
[FONT=Century Gothic, sans-serif]PCGH 100€ [/FONT]
[FONT=Century Gothic, sans-serif]Soundkarte:[/FONT]
[FONT=Century Gothic, sans-serif]Soundblaster X-Fi Extreme Music[/FONT]
[FONT=Century Gothic, sans-serif]Gamestar 65€ Internet 62€[/FONT]
[FONT=Century Gothic, sans-serif]Was sagt ihr zu dieser Zusammenstellung? Machen die Komponenten zusammen Sinn?
[/FONT]
[FONT=Century Gothic, sans-serif]Würdet ihr eher die Teureren Elemente (Grafikarte/ Prozessor) oder die günstigeren preferiren?[/FONT]
[FONT=Century Gothic, sans-serif]Vielen, vielen Dank! [/FONT]
Bei der Grafikkarte würde ich dir die von Asus empfehlen.
Und dazu würde ich dann auch gleich ein Asus Board nehmen. (Asus P5k Deluxe oder so)
Kühler: Scythe Mine, Ninja Plus oder Infinity
Netzteil: BeQuiet Straightpower 550W oder Corsair HX520
RAM: 2GB reichen mehr als aus, in spielen ist es sogar schneller als 4gb
mhh
Das Mainboard ist Test- und Preisleistungssieger bei der PCGH da kann man doch kaum was falsch machen oder?
zum Netzteil: Ja vll sind 550w besser weil ich mir die SLi option offen halten möchte .. aber geht das mit dem Mainboard? Ist doch Standart oder?
Ich will ja nicht nerven, aber ich würde den PC gerne die Tage bestellen 😛
Mein Hauptproblem ist die unsicherheit ob ein 500W netzteil reicht wenn ich mir die Slioption offen halten will?
Und ob das Mainboard das packt .. ^^
Vielen Dank! :bigok:
Geh doch einfach mal auf den folgenden Link:
Allerdings diese Seite bitte mit dem Internet Explorer öffnen.
Firefox funzt nicht. Jedenfalls bei mir nicht.
Dort dann alles hübsch eintragen, was reinkommt und am Ende siehst du, wieviel du verbrauchst.
Fertig.
geiler link^^ thx
@ traced also wenn du SLI betreiben willst bräuchtest du nach dem Link ein 650W-700W NT und wenn du SLI betreiben willst brauchst du auch ein anderes Board mit einem nForce Chipsatz, der Intel unterstützt nur Crossfire (ATI Karten..).
Also ich halte persönlich nichts von SLI, da zu wenig Leistungssteigerung...
Also würde ich beim Board bleiben und auch n 500W NT nehmen.
Ok .. könntet ihr mir ein Board und ein Netzzeil empfehlen?
Also welches die Sli option offen hält und euch gefällt bzw gut ist 🙂
Interessanter Link !!
Laut des Rechners bräuchte ich 400W, da bin ich ja mit meinen 500W gut bedient 🙂
@ Treadersteller
SLI rate ich dir ebenfalls ab, Zu Teuer, Zu viel Strom, Mehr Hitze, und brauchen tust es eh nicht.​
Doch, ich werde es tun .. und zwar wenn die 2te Graka deutlich günstiger ist
BITTE SAGT MIR DOCH EIN SLIBOARD UND EIN 7ooW 🙂
Vielen Dank!
SLI ist wirklich nur was für enthuisiasten. Wenn du wirklich SLI benutzen willst musst du dir jetzt die beiden GPUs kaufen, denn wenn die momentane GPU Generation billiger wird dann steht bereits eine neue Generation vor der Tür die der alten um ein vielfaches überlegen ist. Ich verwette meine schwester dass wenn du eine 8800GTX hast, du dir keine 2te holen wirst 😉
Jaa, ich glaube das Amigo Xtasy entweder völlig übermüdet ist, oder gesoffen hat 🙂🙂.
Wenn ich recht entziffer passt das aber trotzdem...
