Probably caused by: Ntfs.sys
NexYY
Heyho.
Bin jetzt wieder von Linux auf WinXP-32bit umgestiegen und habe natürlich gleich mal Bluescreens ohne ende >.< .
Habe sie mit dem Debugtool von Microsoft auswerten lassen. Kann mir da jemand vielleicht helfen?
Spoiler:
Nummer 1:
Loading Dump File [C:\WINDOWS\Minidump\Mini122109-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image ntoskrnl.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows XP Kernel Version 2600 (Service Pack 2) MP (2 procs) Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Machine Name:
Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055c700
Debug session time: Mon Dec 21 23:20:22.953 2009 (GMT+1)
System Uptime: 0 days 0:01:09.716
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 1000000A, {0, 2, 1, 8050bb5d}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** WARNING: Unable to verify timestamp for Ntfs.sys
*** ERROR: Module load completed but symbols could not be loaded for Ntfs.sys
*** WARNING: Unable to verify timestamp for fltmgr.sys
*** ERROR: Module load completed but symbols could not be loaded for fltmgr.sys
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
*** Type referenced: nt!KPRCB ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
Probably caused by : ntoskrnl.exe ( nt+34b5d )
Followup: MachineOwner
Spoiler:
Nummer 2:
Microsoft (R) Windows Debugger Version 6.11.0001.402 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\WINDOWS\Minidump\Mini122209-01.dmp]
Windows XP Kernel Version 2600 (Service Pack 3) MP (2 procs) Free x86 compatible
Machine Name:
Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055d720
Debug session time: Tue Dec 22 09:56:54.625 2009 (GMT+1)
System Uptime: 0 days 2:47:46.377
BugCheck 1000000A, {ba8e8400, 2, 0, 8051736b}
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** WARNING: Unable to verify timestamp for sr.sys
*** ERROR: Module load completed but symbols could not be loaded for sr.sys
*** work. ***
*** work. ***
Probably caused by : sr.sys ( sr+7a27 )
Spoiler:
Nummer 3:
Loading Dump File [C:\WINDOWS\Minidump\Mini122209-03.dmp]
Machine Name:
Debug session time: Tue Dec 22 15:14:41.562 2009 (GMT+1)
System Uptime: 0 days 1:26:43.323
BugCheck 19, {20, 8a443320, 8a443388, a0d0001}
*** work. ***
*** Type referenced: nt!PVOID ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
unable to get nt!MmSpecialPoolStart
unable to get nt!MmSpecialPoolEnd
*** work. ***
*** Type referenced: nt!_POOL_HEADER ***
unable to get nt!MmPoolCodeStart
unable to get nt!MmPoolCodeEnd
*** work. ***
*** work. ***
*** Type referenced: nt!_POOL_TRACKER_BIG_PAGES ***
Cannot get _POOL_TRACKER_BIG_PAGES type size
*** work. ***
*** work. ***
Probably caused by : ntoskrnl.exe ( nt+22f43 )
sieht nach einem treiber problem aus,mal alle treiber neu drauf machen,vorher aber entfernen,treiber am besten von den jeweiligen Herstellerseiten downloaden
Kann es vielleicht an Service Pack 3 liegen? Hab es diesmal automatisch (legal *hust*!) machen lassen. Hörte dass Service Pack 3 Probleme machen soll.
Habe alles neu installiert und eine Zeit lang ging alles ganz gut aber jetzt habe ich fast im 15minuten Takt folgenden Bluescreen:
Spoiler:
Loading Dump File [C:\WINDOWS\Minidump\Mini122909-03.dmp]
Machine Name:
Debug session time: Tue Dec 29 16:25:03.692 2009 (GMT+1)
System Uptime: 0 days 0:19:28.378
Unable to load image Ntfs.sys, Win32 error 0n2
BugCheck 24, {1902fe, a8b23560, a8b2325c, b7e047a9}
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
Probably caused by : Ntfs.sys ( Ntfs+d7a9 )
Scheib mal bei WinDbg bei Datei > Symbol Path (oder so ähnlich) folgendes rein:
Code:
SRV*c:\websymbols*http://msdl.microsoft.com/download/symbols
Dein Problem liegt vermutlich an der ntfs.sys:
Code:
Abgesehen von irgendeinem fehlerhaften Treiber würde mir noch einfallen mal den RAM mit memtest zu checken...
Hab den Memtest durchgehen lassen, der beim booten im GrubLoader steht(bekam ich nach Ubuntu Installation).
Nach dem Memtest ist alles in Ordnung.
Also hab das bei WinDbg gemacht aber irgentwie passiert nichts^^
File->Symbol File Path->
SRV*c:\websymbols*
Ich probiere es jetzt mal mit neu install von Windows, habe alle Programme etc eh auf ner anderen Partition.
