PC Propleme mit CoD UO
ista68
Ich habe ein proplem mit dem spiel ich möchte des spiel starten dann komm das:
CODUO MP 1.41 build win-x86 Aug 23 2004
----- FS_Startup -----
Current language: english
Current search path:
D:\Programme\Call of Duty\uo\pakuo06.pk3 (12 files)
D:\Programme\Call of Duty\uo\pakuo05.pk3 (3 files)
D:\Programme\Call of Duty\uo\pakuo04.pk3 (7646 files)
D:\Programme\Call of Duty\uo\pakuo03.pk3 (2275 files)
D:\Programme\Call of Duty\uo\pakuo02.pk3 (790 files)
D:\Programme\Call of Duty\uo\pakuo01.pk3 (1652 files)
D:\Programme\Call of Duty\uo\pakuo00.pk3 (6231 files)
D:\Programme\Call of Duty/uo
D:\Programme\Call of Duty\main\paka.pk3 (41 files)
D:\Programme\Call of Duty\main\pak9.pk3 (149 files)
D:\Programme\Call of Duty\main\pak8.pk3 (235 files)
D:\Programme\Call of Duty\main\pak6.pk3 (3 files)
D:\Programme\Call of Duty\main\pak5.pk3 (4858 files)
D:\Programme\Call of Duty\main\pak4.pk3 (1668 files)
D:\Programme\Call of Duty\main\pak3.pk3 (1992 files)
D:\Programme\Call of Duty\main\pak2.pk3 (694 files)
D:\Programme\Call of Duty\main\pak1.pk3 (2642 files)
D:\Programme\Call of Duty\main\pak0.pk3 (12816 files)
D:\Programme\Call of Duty/main
File Handles:
49987 files in pk3 files
execing default_mp.cfg
couldn't exec language.cfg
couldn't exec uoconfig_mp.cfg
couldn't exec autoexec_mp.cfg
========= autoconfigure
configure_mp.csv: using configuration 2200 cpu MHz 256 sys MB 256 vid MB
execing configure_mp.cfg
cl_language will be changed upon restarting.
fs_basegame is write protected.
fs_basepath is write protected.
fs_homepath is write protected.
Hunk_Clear: reset the hunk ok
...detecting CPU, found AMD w/ 3DNow!
Measured CPU speed is 2.21 GHz
System memory is 1024 MB (capped at 1 GB)
Video card memory is 1024 MB
Streaming SIMD Extensions (SSE) supported
Winsock Initialized
Opening IP socket: localhost:28960
Hostname: tobias-pc
IP: 192.168.1.5
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\system32\opengl32.dll' ): succeeded
...setting mode 6: 1024 768 FS
...using colorbits of 32
...calling CDS: ok
...registered window class
...created window@0,0 (1024x768)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...39 PFDs found
...hardware acceleration found
...PIXELFORMAT 3 selected
...creating GL context: succeeded
...making context current: failed
...failed hard
...restoring display settings
...WARNING: could not set the given mode (6)
...shutting down QGL
...unloading OpenGL DLL
Forcing 800x600 resolution to allow OpenGL to run in fullscreen
...initializing QGL
...setting mode 4: 800 600 FS
...calling CDS: ok
...created window@0,0 (800x600)
video card cannot set mode 800x600 because GL_MAX_TEXTURE_SIZE is only -134671825
...WARNING: could not set the given mode (4)
Forcing 640x480 resolution to allow OpenGL to run in fullscreen
...initializing QGL
...setting mode 3: 640 480 FS
...calling CDS: ok
...created window@0,0 (640x480)
...39 PFDs found
...failed hard
...WARNING: could not set the given mode (3)
----- CL_Shutdown -----
RE_Shutdown( 1 )
OpenGL konnte nicht geladen werden. Überprüfen Sie, dass Sie die neuesten Treiber vom Hersteller Ihrer Grafikkarte aus dem Internet geladen haben.
Brauche schläunigs hilfe !!!
Mfg
Ista
Ja.
ATI Radeon HD 5450
Jetzt Geht das wieder ich habe Omega Drivers installiert und die Normalen Deinstalliert!
Trotzdem Danke Heimdall ..
Mfg
Ista
