Slave Festplatte wird nach Umbau nicht erkannt
iosman123
Hello,
I have bought a PC and built in the "old" PC second slave harddrive in the new PC. But she was not recognized there. Have tried it on the file management. Then she appeared in the workplace. After clicking, however, the question: HDD is not formatted - do you want to format now? Of course, I did not do that. Next attempt: built into external housing and connected via USB - the same question. Then I reinstalled it in the old computer, where it was originally something in it. Unfortunately the same. What did I do wrong and how can I get my data? Is very important.
thanks
iosman
Hello,
I have bought a PC and built in the "old" PC second slave harddrive in the new PC. But she was not recognized there. Have tried it on the file management. Then she appeared in the workplace. After clicking, however, the question: HDD is not formatted - do you want to format now? Of course, I did not do that. Next attempt: built into external housing and connected via USB - the same question. Then I reinstalled it in the old computer, where it was originally something in it. Best Quiet Air Compressors Unfortunately the same. What did I do wrong and how can I get my data? Is very important.
thanks
iosman
thanks my issue has been fixed.
Hey,
we need more informations.
What´s your operating system ? Your post suggest me, that it is an IDE Harddisc. Is that true ?
In this case check the position of the jumpers.
Usaly there are 5 possibilutys
Primary Master
Primary Slave
Secondary Master
Secondary Slave
Cable Selected
So try the two postiona for slave, and if they doesn´t work at last the cable selected.
If you use an externel housing, the jumpers has been switched on "primary master", otherwise it doesn´t works.
Good luck
bye
