Täglicher Absturz
GästeFrage
Hallo zusammen,
ich bin total verzweifelt. Einmal täglich startet mein Rechner neu und ich habe keine Ahnung, weshalb. WhoCrashed sagt dazu nur folgendes:
crash dump file: C:\WINDOWS\Minidump\041218-53171-01.dmp
This was probably caused by the following module: nt_wrong_symbols.sys (nt_wrong_symbols)
Bugcheck code: 0x124 (0x0, 0xFFFFBD0CD9FC88F8, 0x0, 0x0)
Error: WHEA_UNCORRECTABLE_ERROR
Bug check description: This bug check indicates that a fatal hardware error has occurred. This bug check uses the error data that is provided by the Windows Hardware Error Architecture (WHEA).
This is likely to be caused by a hardware problem.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: nt_wrong_symbols.sys .
Google query: nt_wrong_symbols.sys WHEA_UNCORRECTABLE_ERROR
Für jeden Tipp wäre ich dankbar!
Liebe Grüße
