[V]PC Chips M 825G
Status
TESLA
Verkaufe das PC Chips board inklusive AMD Sempron 3000+ und CPU Lüfter, CPU ist direkt am Board verlötet daher kein einfacher austausch möglich
Specification
CPU
Socket A for AMD Athlon XP / Sempron processor
FSB
333/266 MHz
Chipset
KM266 Pro / 8235
VGA
Embedded UniChrome 2/3D Graphics w/ 64M share memory
Memory
2 x 184-pin DIMM sockets support two 2.5V DDR SDRAMs (DDR333/266)
Maximum: 2GB
Expansion Slots
1 x AGP 4X
2 x PCI slots
1 x CNR slot
LAN
VIA VT6103 10/100Mbps Fast Ethernet PHY
Audio
C-Media CMI9761A 6-channel audio Codec
Compliant with AC'97 2.3 specification
IDE
2 x UltraDMA 133/100/66
Back Panel I/O Ports
1 x PS/2 keyboard
1 x PS/2 mouse
1 x Parallel Port
1 x Serial Port
1 x VGA port
4 x USB 2.0 Ports
1 x RJ 45 Port
1 x Audio I/O (Line-in, Line-out and Mic-in)
Internal I/O Connectors & Headers
20-pin ATX power supply connector
4-pin ATX 12V power supply connector
1 x Floppy connector-support 360K~2.88MB FDDS
1 x IrDA for SIR header
1 x USB header support additional 2 USB2.0 ports
1 x Front panel audio header
1 x Speaker header
CPU / SYS FAN headers
1 x CD in header
1 x Front panel switch/LED header
1 x SPDIF header
System BIOS
AMI 2Mb Flash ROM
Supports Plug and Play 1.0A, APM 1.2, Multi Boot, DMI
Full support for ACPI revision 1.0 specification
Form Factor
Micro-ATX Form Factor, 244*190mm
DA ICH DAS BOARD UND DEN PROZESSOR MOMENTAN NICHT TESTEN KANN VERKAUFE ICH ES AUSDRÜCKLICH ALS DEFEKT!!!!!
MINDESTPREIS 10€
Sofortkauf: 20€
Status
