Wie lange dauert Prime?
prime95 (vermute du meinst das) hat keine "Laufzeit". Das läuft so lange du es aktiv lässt.
Die Einstellung die du meinst, hat damit nichts zu tun:
The "Time to run each FFT size (in minutes)" value controls how much time Prime95 spends running FFT tests of a given size. Once it has tested one size for that long, it moves on to the next size. It cycles continuously through the sizes within the min to max range until it gets an error or you stop the test.
