Win 7 64bit mehrmals Bluescreen
Nemaides
Hey Leute,
hab gerade Win 7 Professional 64bit installiert (final von der Uni) . Hat alles wunderbar funktioniert. Nur kam jetzt schon 2mal ein Bluescreen und der PC hat neugestartet.
Hab mit windbg mal die Crash-Dumps ausgelesen und kam folgendes herraus:
Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\091109-19921-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image \SystemRoot\system32\ntoskrnl.exe, Win32 error 0n2
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7600.16385.amd64fre.win7_rtm.090713-1255
Machine Name:
Kernel base = 0xfffff800`02603000 PsLoadedModuleList = 0xfffff800`02840e50
Debug session time: Fri Sep 11 18:55:00.254 2009 (GMT+2)
System Uptime: 0 days 0:10:25.971
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 3B, {c0000005, fffff8000291e0fa, fffff88008f930d0, 0}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
*** Type referenced: nt!KPRCB ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
Probably caused by : ntoskrnl.exe ( nt+31b0fa )
Followup: MachineOwner
--> Probably caused by : ntoskrnl.exe ( nt+31b0fa )
sagt das jemandem was? Wodran könnte das liegen und wie kann ich das vll. lösen?
Hoffe Jemand kann mir helfen.
Danke schonmal,
Nemaides
google? wenn es da net steht dann wird es schwer, weil noch nicht so viele dieses Betriebsystem gut kennen.
Den Fehler dieser Datei gibts wohl auch bei Vista usw. aber hab noch keine richtige Lösung gefunden.
Mir ist aufgefallen das das immer passiert wenn ich was Installieren will.
Der Debugger verweist aber auf fehlerhafte Symbole der ntoskrnl.exe - gib mal folgendes in die Eingabeaufforderung ein:
Code:
[B]Set _NT_SYMBOL_PATH = symsrv*symsrv.dll*f:\localsymbols*http://msdl.microsoft.com/download/symbols[/B]
Steht in dem Link von mir drin.
Ok, hab ich gemacht, kam auch schonmal keine Fehlermeldung. Kann ich irgendwie testen ob das funktioniert hat oder muss ich nochmal ne Installation versuchen und nen Bluescreen riskieren?xD
Jetzt hab ich paar min nix gemacht und das Bild hängt. Kann nix mehr machen und Passiert nix. Alles steht.
Im mom kommen auch keine Bluescreens mehr, er hängt sich nur noch auf, geht gar nix mehr seh nur ein stehendes Bild. Das ist eben z.B. passiert als ich Drucker über USB angeschlossen hab, kam GeräteTreiber installieren und da ging nix mehr. Ist aber auch schon öfters so passiert.
Weiß nicht mehr weiter=(
hier mal der besagte Bluescreen.
